how to remove an S3 seat??
jediknight Dec 26, 2006
  1. jediknight
    jediknight Member
    835
    still cant find the source of my fecking rattle. so out with the seat and see if i can get to it then
    anyone know how it comes out though before i head out there and spend hours messing with it.
    ta
  2. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Khufu has a concise workshop manual for the interior online here:
    http://myweb.tiscali.co.uk/macnee/downloads.html
    Regards,
    Rob.
    EDIT: The short version though; there should be a trim panel on the front-side of the base of the seat which you can pop-off (my pre-owned Recaros didn't have them though) - once you've got that off you should see a plate with either two bolts and a locating pin of sorts, or one bolt and two pins (memory failing me). Undo the bolt(s) there and push the seat towards the back of the car (but carefully though - there are stilll electrical connectors hooked-up underneath you don't want to damage :)) - once you've got the seat back far enough you should be able to manipulate it to get better access to the electrical connectors so you can un-hook them (precision screwdrivers come in handy here for undoing the cilps on the connectors as they're a bit fiddly).
    Regards,
    Rob.
