how to refit drivers side cubby trim
benr Aug 9, 2008
  1. benr
    benr Member
    819
    hi i removed the trim under the sterring wheel with the light switch etc on, to look at the G200 sensor as i will need to replace it at some point.
    However im having a nightmare trying to get the trim back in place correctly so all the screws line up. Elsa says "When installing, slide bottom of compartment into the two guides." what are the 2 guides? is it the white plastic clip things becuase thats what i tried.
    any tips would be great thanks
    Ben
  2. benr
    benr Member
    819
    bump anyone got any tips please gonna tackle it in a bit again
  3. Ibzzzzz
    Ibzzzzz Member
    678
    that'll be these two guides
    When i was having the same problem i found that taking out the whole headlight switch helped, IIRC you push the switch in and turn it by the time it gets the sidelights position it should come out.
  4. Ibzzzzz
    Ibzzzzz Member
    678
    Plus have you got it into this clip too?
  5. benr
    benr Member
    819
    Wicked thanks for your help, all done now, will have to do it again to replace the sensor but feel like i can do it now. tx
    Ben
  6. Ibzzzzz
    Ibzzzzz Member
    678
    No Problem!
