How to programme your audi key fob ( Instructions )
shawshankuk
Glu Kru
Scotland
After mentioning that I know how to do this I've had a few requests from people for the information so thought it would just be best to put it up on the forum for you all to see.
Enjoy
How to programme Audi VW Seat Skoda remote keys 1. Take the valet key, put it into the ignition and turn the key to the "on" position, just prior to starting the car. 2. Roll down the driver's side window (not required, but a good idea in case there's a problem). 3. Exit the car and close the door. 4. With a second key, physically lock the doors (don't use a remote). 5. Take the first remote to be programmed, press one of the buttons and the lights will flash once. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed. 6. Lock the door again (physically) with the key, (not the remote). 7. Press one of the buttons twice, the lights will flash twice. Wait 10 seconds and press the unlock button. The doors should unlock. The second transmitter is now programmed. For a third transmitter press the button 3 times and for a fourth press 4 times. Make sure that to test the newly program remotes, the original key is removed from the ignition. Someone might be a bit frustrated trying to test it with it still in 'program' mode. If you are having problems check the key is right one for year of car, the key and battery are good. Sometimes when trying to program the key it won't turn in the ignition stopping you from following the rest of the steps to program the key, when this happens it is the transponder chip in the key that sends and receives info from the immobiliser for starting the car, If this happens it will need to be synchronized/coded to the immobiliser at a good local locksmith or other specialist to proceed with the rest of the steps. If you have a Ford Galaxy, VW Sharan or Seat alhambra-
Hold key in drivers door lock, turn to unlock 3 times, this illuminates red
light in driver's door.
Press and hold the unlock button on key and press the lock button 3 times to
get light in driver's door flashing again.
You galaxy remote key should now be programmed.
Reactions: MPH, Ian Bevan and spiker
This programs the remote for the lock/unlock feature, the immo chip cant be done with this procedure
you dont have to do half of that stuff ..
Tried other shorter tutorials but none worked for key number two. This worked first go on an A3 8L!
984
760
875
676
