How to open the boot with out the key fob?
A3matt Apr 16, 2010
  1. A3matt
    A3matt Member
    37
    i have no battery on my car......how do open the boot without the key fob? on the audi a3 sportback 2006
  2. Hellz
    Hellz Geordie Racer
    381
    You can only open it from the inside I believe, there should be a latch inside to release the boot lock.
  3. KRL
    KRL Member
    521
    Take the back seats down? Not sure of any other way.
  4. Paul_c
    Paul_c Member
    139
    Use the button on the drivers door to disable all door locks. Then press the micro switch on the tailgate handle?
    Tom Hutcheson likes this.
  5. Dec
    Dec Active Member
    319
    30
    How do you do this? never seen a boot release inside the car, unless it's because mine is an older 04 plate. :(
  6. consilio
    consilio Up the owls!
    666
    This would only work with a battery, which the OP does not have
  7. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    You will have to climb through into the boot.
    Have a look at the rear tailgate from inside, and central near the bottom of the tailgate, you will see a blank plate about 25mm square. Pop this out and it should give you access to manually over ride the boot catch.
  8. smudge_don
    smudge_don Active Member
    2,944
    All other Audi's have boot release button in the car apart from A3's
    Never understood this
  9. voxy53
    voxy53 New Member
    Hi
    On the 3 door, if you get in the car, lower the rear seats, there is a horizontal slot about 3ins long in the boot trim panel.
    Put your ignition key into this, and slide one way or the other (can't remember which way) and the lock will open.
    I have a 2005 3 door 2.0T and have had to remove the door trim to sort out a leaking rear wiper motor.
    Hope this helps
    voxy53
