HOW TO - I DONT KNOW?
swarcup Sep 28, 2009
  1. swarcup
    swarcup Well-Known Member
    1,326
    40
    PLEASE HELP
    The first question i hope is straight forward i have a 2001 a4 avant quattro sport 180 engine no AKE
    im told by audi there are 2 temp senders, 1 for the ecu (green with 4 wires on) which i have changed and 1 for the temp guage(poss black 2 wires on) where is the location of the 2 wire sender and how to access it would be appreciated. reason is temp guage is reading low and occasionaly stops working so need to change sender first
    my other question is how the dickens do you remove the boot door linings to access rear of number plate lights- ive tried removing the 2 bolts behind the warning triangle and the two in the grab handles but it is still fixed somehow- anyone know how it is done?
  2. quattrojames
    14,060
    583
    With reference to your second question, I have never done it but have seen questions on it. I think after those fixings are out it's just held in by 'clips'. It just requires a good firm but gentle pull and it should come free, but as I say I can't actually speak from experience ....
  3. b00zehound
    b00zehound Member
    90
    been doing this today on the avant.....there are 4 screws to remove on then it pulls off. It is a bugger of a job to get it off
  4. yendall24
    yendall24 Member
    571
    i was always under the impression that the green temp sensor 4 pin sent info to both the ecu and the gauge ? there is one similar black sensor its in the bottom radiator hose but i think this one is for the electric cooling fan every time i have had a temp gauge problem i have only ever changed the green one
  5. BILKO1
    BILKO1 Member
    301
    Just the four screws and pull really hard all that holds it on are sping clips that are really strong. I used a plastic wedge so i could get my fingers under the trim then pulled like hell.
  6. aragorn
    18,545
    865
    Yer if its got a 4 pin sensor its combined dashboard and ECU.
    Earlier cars had two (like pre mid-90's models)
