How to get wires from the engine bay to the cabin? A4 B7
Richardesty Dec 2, 2008
  1. Richardesty
    Richardesty loves quattro
    742
    20
    Has anyone managed to find a route for an extra wire to go between the engine bay and the cabin?
    I can't seem to find an obvious route - any advice will be greatly appreciated.
    Rich
  2. NHN
    29,284
    1,695
    well try looking under the wiper plastic panel where the battery is(i think on b7 as my b6 s4 was) might be a rubber grommet there with spare holes to break that you could go through, the 8P has them behind the battery that comes in the cabin behind the glovebox by the heater module, make sure you seal up with sealant to stop any condensation build up.
  3. Richardesty
    742
    20
    Brilliant - thanks I'll have a look.
    Rich
  4. AndyMac
    9,832
    45
    The other option is to go via the ECU cover, there's usually a spare grommet on the big rubber boot going into the ECU, and then this drops down into the footwell.
  5. stevehall
    stevehall Member VCDS Map User
    300
    How do you remove the ECU cover? I guess this is the bix box on the right hand site under the wiper blades?
    I have a crack in mine and i want to change it, but i cant seem to get the old one off.. I cant get to all the torx bits
  6. Richardesty
    742
    20
    Yeah - I've never got past the back left one either.......
    Any tips people?
  7. stevehall
    300
    I am going to have a go tomorrow as I have cracked mine through messing about with it, and i need to get it back fixed so its water tight...
  8. stevehall
    300
    Found a guide on the net, and app you need to remove the wiper, and then you can access all the bolts..
    I dont have the url any more, but i have the file saved - pm me your email address and i will send it.
  9. Richardesty
    742
    20
    Hmmmm - that would make sense!
    I've also been advised that there are a couple of rubber grommets adjacent to the battery that pass through the fire wall behind the glove box - might give them a go instead.
    Rich
  10. Richardesty
    742
    20
    Well I found an even easier route - thought the Pollen Filter Housing:huh:
    Just gotta wait til dusk to show you what I've been up to :whistle2:
