how to get off metal raised badges?
willnabby Apr 23, 2007
  1. willnabby
    willnabby RS-one day soon!!
    605
    does anyone know how to ge raised badges off without damaging the paint? I thought about using a credit card behind it but thought I'd ask you all for advice.
    Thanks in advance:icon_thumright:
  2. Hotscar
    Hotscar Four Wheel Drifting
    562
    I read on here to use hot water and dental floss and I have to say, it worked a treat!
  3. MrJoshua
    MrJoshua '98 A4 2.4 SE
    104
    Yep, hot (but not boiling) water, dental floss and a hairdryer are my weapons of choice when tackling adhesive-backed badges.
  4. sat1983
    sat1983 Member
    848
    15
    Yep dental floss is best. Did this myself, was very easy.
  5. willnabby
    605
    cheers guys, floss it is then:icon_thumright:
  6. willnabby
    605
    I started with the dental floss and stopped part way through till I get more advice, It was working fine but as i've checked progress behind the badge I've noticed it leaves the foam adhesive backing still on the car body, am I doing it right? if so how do you get the foam adhesive off without damage to the paint:think:
    Cheers in advance for any replys.
  7. benw123
    benw123 Moderator
    1,863
    Use WD40. This loosens the adhesive and you can gently wipe it off. Might take a while but it will disappear without any risk to the paintwork.
  8. willnabby
    605
    So take the metal badge off first then use the wd after?
  9. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    You need some heat! Hair dryer or heat gun on lowest setting will soften the adhesive, meaning it can be gently rolled off using a fingertip and mild rubbing pressure. So, the order is, heat the area until warm, use the floss to remove the badge, rewarm, then rub the adhesive with a fingertip firmly and you will find it starts to lift and roll up and come off. Chances are you'll be left with a slightly sticky residue after the adhesive tape is removed, but a gentle wipe with a citrus degreaser or all purpose cleaner will cut through this and leave the paint perfectly smooth. I use the same method when swapping my metal number plates (I use sticky pads to hold them on). :)
