How To: Fitting A HID Kit to A3 8L
A3 T Jun 2, 2011
  1. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    I noticed there isn't any guides out there for fitting these kits to an a3 8l and questions about fitting them keep popping up, so as i fitted mine today i thought i would do a quick guide.
    All you will need is a drill , drill bit and some insulation tape
    Here is the kit i bought....
    Its just a basic 6k 35w H1 kit with no mention of canbus....etc:
    You will first need to remove the covers from the back of the headlight:
    You do this by pushing down the tabs (circled):
    Once you've got the cover off you'll need to drill a hole to pass the wires through.
    some people make a cut in the bottom of the covers to allow the wires to pass in to the headlight i i wanted to make sure there was some sort of seal round the wires, but its up to you.
    I cleaned the holes up after with a bit of sand paper (not shown in the pics)
    Now pass the wires and part of the seal through the hole :
    Back to the car...
    Pull the brown and the yellow wire from the back of the headlight , unhook the wire bulb holder and withdraw the bulb you are about to replace:
    Now replace the bulb with your new hid one:
    You now need to connect up the wires from the hid kit to your factory wires:
    Yellow goes to red and brown goes to black.
    I did find that i had to squash the factory terminals with pliers as it was a bit of a loose fit.
    And insulate the wires (i only did one in this pic):
    Now replace the cover reverse to removal:
    Next connect the red and black wires to the wires coming out of the ballast, and plug the connector into ballast:
    You'll now need to find somewhere to mount the ballast....
    My ballasts had a sticky pad on the back of them , so i mounted the drivers side one one the headlight cover (i fixed the rubber seal after the pic was taken....lol)
    And the passenger side one on the inner wing:
    That's it turn them on :)
    Before :
    After:
    Do you think i went too blue ? .....lol
    I hope this helps some of you out there ;)
    Ashley =1.8T= likes this.
  2. DenCar
    DenCar Member
    404
    Great i love it well done and good pics, what camera did you use?
    DC
  3. A3 T
    1,077
    15
    Thanks mate ;)
    Believe it or not i used my blackberry......lol
  4. DenCar
    DenCar Member
    404
    Wow, nice clear pics, iv got an iphone the earlier one, and its not too good at photos. I also shoot amature stuff with a nikon D90, thats my second love after cars.
    DC
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Great Guide mate....
  6. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    great guide :salute:
  7. bhavin1986
    bhavin1986 BBP
    464
    Nice guide mate. This should be put into the A3/S3 FAQ sticky.
    PM a mod and ask them about it dude.
  8. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    yeh should def go in there. its a good guide
  9. A3 T
    1,077
    15
    Thanks for the comments guys ;)
  10. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,269
    2,090
  11. sulaiman
    sulaiman Member
    274
    Worth mentioning, you should add some silicone sealant once you have passed the grommet and wires through the cover to stop the headlamps steaming up and be 100% sealed.
  12. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,368
    908
    Good effort, well done...
  13. A3 T
    1,077
    15
    Thanks mate :thumbsup:
    I didn't find that necessary as the grommet was already fitted to the wires so had a good seal and once it was pushed through the hole i made in the cover it was so tight it was like it was meant to be there....lol
  14. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,131
    358
    Thanks for that A3 T, i consider HID but never thought it was that simple!
  15. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,188
    Without sounding like a massive twat, how do we have a totally illegal modification as a sticky?
  16. Lewis583
    956
    91
    Especially when there has been no mention of at least having your headlamp aim checked afterwards to ensure you aren't blinding everyone on the road.
  17. Paul_TDi
    Paul_TDi Active Member
    369
    HID's aren't illegal.
    I think common sense prevails when playing about with headlights you ensure your beam pattern/height is correct.
  18. S3_chris 11
    S3_chris 11 Member
    188
    What do these look like whilst driving down the road as I can't stand my standard lights any more as on low beam u cant actually tell on the road that ur lights are on lol. They do many versions of HIDs which one looks best in a3s and are they all ok in plastic headlights??
  19. Paul_TDi
    369
    My headlights are pretty shocking at the minute too, no HID's for me until I have restored the lenses are there pretty scratched at the moment. I suspect the bulbs are fairly old cheap ones too.
    I don't have any comparison shots but they do make a huge difference. If you don't have projector headlights be sure to buy the anti glare versions so you don't blind other road users. HIDs4U are a great shop.
  20. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    A3 oem xenons have smaller diameter lenses then halogen ones, I'd be interested to see how the beam pattern is affected, I have OEM fitted right now, but toying with selling them for some later + driving light style aftermarkets now :D
  21. Tim_Attard
    Tim_Attard Active Member
    473
    44
    just got a kit of ebay, looks exactly the same as urs but its coming up with a bulb error when plugged in, when i swap back to standard its fine, any ideas? its connected up exactly the same
  22. aloakos
    aloakos New Member VCDS Map User
    26
    13
  23. reno85
    reno85 New Member
    20
    Fitted mine last week, and this guide helped loads! what a change to the apperance of car aswell!
  24. SHUk
    SHUk Once Bitten Forever Smitten =]
    306
    19
    Where have the pictures gone...?
  25. Tj 0785
    Tj 0785 Well-Known Member VCDS Map User Bronze Supporter Audi S3
    1,665
    353
    Aren't they illegal if you have got the level/range sensors in the wheel arches
