How to display car speed on Air Con display?
turbodan Aug 7, 2005
  1. turbodan
    turbodan Member
    144
    Hi there
    Just sold my MR2 Turbo and bought an Audi A3 TDi Sport (Sick of the high running costs of the toyota!)
    I see some people on ebay are trying to sell instructions of how to display the cars speed on the climate control display?
    Just wondered if any of you guys new how to do it and could give me instructions?
    Cheers - Dan
  2. Kevint
    Kevint Active Member
    1,182
    Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
    NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
    Code Displayed Value
    1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
    2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
    3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
    4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
    5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
    6 Digital value of Outside Air (Ambient) Temperature Sensor
    7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
    8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
    9 Delta value of Temperature Regulator Flap
    10 Non-corrected specified value of Temperature Regulator Flap
    11 Digital value of Central Flap Motor Potentiometer (G 112)
    12 Specified value of Central Flap
    13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
    14 Specified value of Footwell/Defroster Flap
    15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
    16 Specified value of Air Flow Flap
    17 Vehicle Speed (km/h)
    18 Actual Air Blower voltage (Volts)
    19 Specified Fresh Air Blower voltage (Volts)
    20 A/C Compressor (A/C Clutch) voltage (Volts)
    21 Number of low voltage occurrences, non-transient
    22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
    23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
    24 Cyclings of the switches, absolute non-fluctuating
    25 Analog/Digital value, Kick-Down Switch
    26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
    27 Coding value
    28 Engine Speed (RPM)
    29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
    30 Software version
    31 Display check (all segments of A/C Control Head display light up)
    32 Potentiometer malfunction counter, Temperature Regulator Flap
    33 Potentiometer malfunction counter, Central Flap
    34 Potentiometer malfunction counter, Footwell/Defroster Flap
    35 Potentiometer malfunction counter, Air Flow Map
    36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
    37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
    38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
    39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
    40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
    43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
    44 Vehicle operation cycle counter
    45 Calculated interior temperature (internal software, in digits)
    46 Outside (ambient) temperature, filtered, for regulation (internal software)
    47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
    48 Outside (ambient) temperature, unfiltered, (in digits)
    49 Malfunction counter for speedometer (vehicle speed) signal
    50 Standing time (in minutes)
    51 Engine Coolant Temperature (ECT) in deg C
    52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the “88.8” display. See chart below.
    53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the “88.8” display. See chart below.
    54 Control characteristics
    55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
    56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
    57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
    58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
    59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
    60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
    61 Software version (latest)
    Kev.
  3. Kev - Does this work on the B6 A4 ?
  4. Kevint
    1,182
    I'm really not sure, sorry.
    Kev.
  5. If I changed this, will it still show the temp I want the climate control at?
  6. scoTTy
    scoTTy Active Member
    1,962
    This doesn't work on the new models i.e. not on B6/7, new A3, etc, etc
  7. [ QUOTE ]
    [/ QUOTE ]
    Cheers Scotty - I thought not, but just wanted to check !
  8. Kevint
    1,182
    [ QUOTE ]
    [/ QUOTE ]
    It will show the information you request until you reset it back to temp.
    Kev.
  9. turbodan
    turbodan Member
    144
    Cheers mate.
    Just what i needed.
  10. dgannon69
    dgannon69 Member
    475
    hey mate, so lets say i set it to the vehicle speed setting. which code am i going to need to set it back to the original display for the air con. thanks in advance...
  11. Kevint
    1,182
    No code, just hit auto or maybe even some of the other buttons cancel it, but that will throw you back to the temp screen.
    Kev.
  12. jpda4
    jpda4 Member
    129
    21
    it only gives reading in km/h
    hope your maths is good to convert as you driving!!!
    i know mine isnt
  13. Kevint
    1,182
    [ QUOTE ]
    i know mine isnt
    [/ QUOTE ]
    Or you could just look at your speedo and read off kph/mph /ubbthreads/images/graemlins/wink.gif
    Kev.
  14. Is the rev counter one any good?
    The speed one is a nice idea. Was racing around with a mate yesterday and he had to ask what speed I reached a few times.
  15. myrichdad
    myrichdad Member
    140
    Not sure that I want the wife to see what speed I'm doing to be honest....best kept secret.
    Although she never seams to mind when it's somewhere she wants to go!!!
    Info is great though. Thanks very much. /ubbthreads/images/graemlins/laugh.gif
    /ubbthreads/images/graemlins/beerchug.gif
  16. darnich
    darnich Member
    106
    Thats very cool..!
    Is there a way to display boost pressure, oil pressure,MAF readings etc? either in the clima display or in the display that shows the radio stations/RDS between the rev and the speed clocks?
    thanks
  17. dpeilow
    dpeilow Member
    95
    Yeah boost pressure was my first thought when I started reading that list...
  18. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    The rev counter is useful, i used it once to monitor issues with the engine and where at certain points in the rev range in various gears a strange juddering sound was made. This helped pinpoint the issue when it went it.
  19. benk
    benk Member
    469
    These values are mainly the information that the climate control system needs to do it's job, which is why they are temp sensor readings and errors, engine speed and revs so it knows how much power it can use, etc.
    I doubt that turbo boost is useful info to the CC system, so I don't think it will show you that.
  20. Kevint
    1,182
    [ QUOTE ]
    Thats very cool..!
    thanks
    [/ QUOTE ]
    Not with the aircon, but an Enhanced DIS will display some of the information you're after.
    Search on here for Enhanced DIS and a link to a .au website, I mailed them recently and they got back to me straight away.
    Kev.
  21. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Hey guys, has anyone been able to actually get the display up? I coudn't, I've got a 2002 S3 BAM, should it work? and should the car be Idle? switched on or off?
  22. Kevint
    1,182
    Car should be on, it does not matter if the car is idle or moving.
    Check the instructions and make sure you're hitting the right buttons (sounds stupid but I was doing it wrong to start with).
    Kev.
  23. Khufu
    Khufu Well-Known Member
    5,704
    31
    it only works on certain aircon panels, not sure if it works on the facelift model.
  24. macattax
    macattax Member
    455
    Very cool!.
    Worked on my facelift model 1999.5
  25. nick1973
    nick1973 Member
    111
    im going to jump on the band wagon and try and sell this onfo on ebay :ermm:
  26. Randomjim
    Randomjim Active Member
    2,752
    i kept looking at the revs going up when i did it
  27. s3shabs
    s3shabs Member
    155
    very clever..i think the maf reading would be good to see whether we have healthy air mass meters..
    i know shaun at big boys toys plugged in the vag com, and found the maf reading of my car to be a little low, so replaced the maf..
    very useful..
  28. Mcblow
    Mcblow Member
    79
    hi.i was messing about with mine as you do when you find this little trick out,but now it shows the temp on aircon in F,how do i get it to return to deg c for the air con ???,as that list below confused me?? cheers
  29. themanthatcan
    themanthatcan Member VCDS Map User
    661
    Think you just need to hold the Recirc button to flick between Celcius and Fahrenheit
  30. Boro&Beth
    Boro&Beth Member
    172
    Awesome, just checked on our 2000 facelift and worked, although, these two codes were the wrong way round:-
    27 Coding value
    RPM was code 27
  31. AudiS3Quattro
    AudiS3Quattro Member
    199
    yes i found that 27 was RPM as well
  32. AudiS3Quattro
    199
    Also does any body know what 61c to 89c mean when i select 86c it looks like its trying to display a graph or somthing, just wondering if any one can help!
  33. WildBruce
    WildBruce Third Gear
    204
    49 Is coolant temp for me, I have been using this for a while, as I like to know how fast the car is warming up, so always set it before I drive off, just to keep a close eye on things as the temp gauge on the dash is well know for rounding off, to stop Audi getting to many calls form worried drivers
  34. Eddie S3
    Eddie S3 Member
    128
    9
    Just thought id bump this for people who havnt seen it, Tried it today in my 2002 BAM and everything worked fine
    Danman1 likes this.
  35. dancuz
    dancuz Member
    140
    What number was coolant temp for you?? Going to try this out tomorrow. Cheers
  36. L33h
    L33h Member
    215
    well you learn something everyday!
  37. Danman1
    Danman1 Thorough noob
    342
    19
    Loved this post. There should be a stickie for 'Things your Audi does but you dont know about'
    Dan
