How to clean N75 valve
dany2k Jan 10, 2011
  1. dany2k
    dany2k Member
    318
    Hi all,
    Can anybody point me in the direction of where the N75 valve is (with a picture if possible) and how to go about giving it a clean... eletrical contact cleaner the thing I need? I've got a couple of days of work and this is just about the only thing wrong with her at the moment, and may as well give it a go :)
    Danny
  2. <tuffty/>
    20,904
    3,713
    ermmm... why do you need to clean it may I ask?
  3. dany2k
    dany2k Member
    318
    a bright spark suggested it a couple of posts ago :) nothing to lose, probably needs replacing really but give it a clean if i can!
  4. <tuffty/>
    20,904
    3,713
    What problem is it you have that means you have to do this? when they don't work they tend to throw a code or drop boost to actuator level...
  5. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    If it's not broken, don't fix it....
  6. dany2k
    dany2k Member
    318
    i'll fill u in mateys, so u dont think im just a madman deciding to clean his n75 just because he's bored :)
    on the 0-30 sprint i feel a slight 1/2 second worth of hesitation: enough of a hesitation for *insert random boy racer car* to gain a decent foothold.
    vagcom flagged up something that pointed towards the n75 valve too: 17963 charge pressure maximum limit exceeded
    it also flagged up something else recently which hasnt come back yet: something relating to the pre-cat o2 lambda sensor.
    any ideas..?
  7. hades-
    9,481
    646
    i doubt you can clean them
    just buy a new 1 if needed
  8. <tuffty/>
    20,904
    3,713
    Check pipes for leaks would be the first thing then get the actuator tested for opening pressure... a boost gauge would be useful to check what boost there is to trip this as would a few logging runs with VAGCOM...
    Not entirely convinced the N75 is at fault here tbh... N75 issues are usually accompanied with N75 fault codes... a new valve is around the £50 mark, expensive if thats not the prob... do you have access to VAGCOM?
  9. dany2k
    dany2k Member
    318
    uv got a point re. the new valve: if im being honest, i changed the MAF in similar circumstances :-( i do have access to vagcom, what should i be looking for? could the lambda sensor fault point to something?
  10. Welly
    10,696
    127
    Normally the Lambda...
  11. quattro1
    quattro1 Member
    639
    heres the n75 mate, check all pipes going to and from it for splits :thumbsup:
  12. dany2k
    dany2k Member
    318
    cheers matey, much appreciated! i'll have a look when the sun rises :) oh... and very nice and clean engine bay btw well done!
  13. quattro1
    quattro1 Member
    639
    sadly not my bay :( lol mine doesnt look too disalike though!!! :laugh:
  14. deano8406
    deano8406 New Member
    where would the best place be to get a new n75?
  15. thegoal007
    thegoal007 Another S3 owner....
    804
    26
    tps.
