how to check the timing on a 1.9tdi (130)
BEELZEDUB Oct 19, 2012
  1. BEELZEDUB
    BEELZEDUB hippy exhaust guru
    22
    as the title suggests, having my car vagcom'ed tomorrow morn, but i think the problem with my car is either diesel pump out of sync if possible or timing is out in some way.
    see my previous topic for symptoms
    most stuff has now been ruled out, but although i've been told the timing has been checked twice i'm just not sure.
    one of my work collegues today mentioned to me that my audi sounds like a tractor.
    mike
  2. adamss24
    adamss24 Well-Known Member
    4,551
    392
    There's no diesel pump on your engine, each injector is a mini pump on it's own- google Pumpe Duse for images and explanations. You cannot set the timing wrong on the pd lump without valve to piston contact however you can adjust the "syncro angle" on the camshaft. You need registered vag com/VCDS for that. Too far either way and the engine won't start. If your engine sounds coarse then i suggest you remove the rocker cover and inspect the camshaft and lifters for wear due to wrong grade of oil used !
  3. BEELZEDUB
    22
    it's getting vagcom'ed in a bit so fingers crossed they find something. thanks for the info chap.
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    Check the synchro angle in engine module group 4 it should be as close to zero as possible
