as above i wont to check it before i replace the cct . And what should it be at low rpm
H harvey01 Registered User Joined Dec 13, 2011 Messages 510 Reaction score 9 Points 18 Location NULL Sep 4, 2012 #1 as above i wont to check it before i replace the cct . And what should it be at low rpm
Lewis583 Active Member VCDS Map User Joined Mar 15, 2010 Messages 954 Reaction score 93 Points 28 Sep 4, 2012 #2 Car? Engine code? Model year? Unscrew oil pressure sensor, screw a oil pressure testing kit in it's place, start engine and observe gauge.
H harvey01 Registered User Joined Dec 13, 2011 Messages 510 Reaction score 9 Points 18 Location NULL Sep 4, 2012 #3 thanks mate its a 2000 s3
Lewis583 Active Member VCDS Map User Joined Mar 15, 2010 Messages 954 Reaction score 93 Points 28 Sep 4, 2012 #4 Autodata states that you should have between 3.5 to 4.5 bar @ 2000rpm
