How to Check Anti Shudder Valve?
Chrismawa Jan 15, 2014
  1. Chrismawa
    Chrismawa Active Member
    457
    46
    I'm not sure if my ASV is functioning correctly, as when i switch the car off I'm getting like a shudder/judder. Is there anyway I can check to see if its working ok?
  2. yendall24
    yendall24 Member
    571
    9
    hi which engine do you have in your car
  3. Chrismawa
    457
    46
    Sorry I should have put that, its a 1.9 TDI (AWX).
  4. yendall24
    yendall24 Member
    571
    9
    ok the anti shudder valve is a black plastic pod with a black plastic plunger coming out of it its attached to the egr valve what you need to do is get someone to switch the engine off whilst you look at the plunger if the plunger shoots out it is working . if it does not shoot out when the engine is turned off that is because the rubber diaphragm within the plastic pod as split this split is usually caused by engine oil vapour from the egr getting into it and and perishing the rubber . the bad news is audi do not sell this part on its own you have to buy the whole egr valve that said i got mine off ebay for 40 quid hope that helps
    Chrismawa likes this.
  5. Chrismawa
    457
    46
    That's great thanks! I will check it at the weekend.
  6. DieselJake
    DieselJake Well-Known Member
    2,941
    748
    Forum member @udi A3 checked mine in vag-com... to which my car choked and died so think mines pretty clogged haha.
  7. mikeygulley
    mikeygulley Member
    30
    Also check that the vac pipes aren't perished or disconnected and maybe check the wiring to the actuator. Mine wasn't working and it turned out to be a broken wire.
  8. whinfs
    whinfs Member
    58
    could someone put a pic of the shudder valve and where it is please? mine shudders when turned off but i've never heard of this...
  9. Chrismawa
    457
    46
    I know this is a different engine layout but its the black plastic pod attached to the EGR valve
  10. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    263
    The EGR could be that clogged that the valve can't shut fully, which would stop it working correctly, and totally eradicating engine shake.
    You could just pop the pipe off to look inside to see if this is the case.
