How to change instrument cluster lights to 8P S3 style** with pics**
S3 Nattie Jan 26, 2010
  1. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
  2. Imteyaz
    Imteyaz 6th Gear
    535
    I don't think it's straightforward changing them as the use sandwich type LED's AFAIK.
    If you are any good at soldering then maybe it's possible but it's certainly not as simple as replacing a few bulbs.
  3. HTC
    HTC Active Member
    3,428
    9
    Surface mount LEDs like you find on mobile phones etc. If you are good with a soldering iron then I'm sure it's possible. Not for the faint hearted though.
  4. Dani_B19
    8,962
    317
    The lights are white anyways, its the dial matt's that are red. I want todo it but no where seems to seel the dial matt's.
  5. S3 Nattie
    1,599
    I didnt think it would be a straight swap with these. If the bulbs are white I might scrap off the red stuff at the back, is that possible.
  6. MURRAYS444
    MURRAYS444 Member
    790
    :s3addict:I was trying to get that sorted today as my ESP and ABS lights are coming on but are very faint I was told by a specialist that they would send the entire instrument cluster away to be fixed by another specialist does anyone know if this is right he also said that if the ABS light wasn’t coming up on the dash when starting the car it was an MOT failure is this right but can you fix this yourself???
  7. Westy
    Westy Well-Known Member
    17,440
    1,096
    Would it not be easier to find dials from another vag car that are the colour you want?
  8. S3 Nattie
    1,599
    I see what you mean but to do a DIS repair you have to take the dials off dont you. I done it on a previous car and just srcapped the red stuff on the back off.
    Dials from others cars wont be calibrated
  9. Westy
    17,440
    1,096
    No I mean just swap over the dial discs not the whole dis and needles.
  10. RyanS3TT
    RyanS3TT Member
    527
    this thread is intresting, Nattie, if you give this a go can you post up pictures because i might try sounds like a worth while mod.. for free :p
    <<Ryan
  11. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I've changed all the interior leds on an astra from yellow to blue and it was a painstaking and fiddly job (a lot of soldering envolved) and took about 2 days but it did look good.
  12. S3 Nattie
    1,599
    Westle - I mean 60mph on a new S3 or TT dials aint in the same place as where it is on our S3 so dont think you could just swap the discs, do you get me.
    Well on my previous car it was dead easy to change the bulbs over or take the backing off the back of the dials. I had white Lockwood dials and chrome outer rims, looked pretty good.
    Im going to have a go at repairing my DIS soon so will have a look to see if I can do something with the dials.
  13. Westy
    17,440
    1,096
    Ah yes, I see what you mean now.
    Well let us know what you do Nattie and get some photos up if you do it.
  14. ssbnreso
    ssbnreso Member
    80
    Well had a go at this today!
    Clocks out
    Before taking out had a look at the led's these are RED not WHITE
    Thought i'd do the clock first in case it went pear shaped!
    Scraped the orange off with a stanley blade (really easy)
    Then used a marker to apply white paint
    Marker
    Then put all back together
    Reassembled
    Close up picture of clock
    Will get some photo's tonight when it's dark to see what it looks like,
    Not sure what it will look like with red light behind?
    If you try changing the led's i'm assuming you would lose all or the red numbers etc
    Any comments more than welcome:icon_thumright:
  15. RyanS3TT
    RyanS3TT Member
    527
    Looks good ssbnreso.. Looking forward to seeing them when its dark.
    <<Ryan
  16. Westy
    17,440
    1,096
    Looks much better mate. Luckily the S3 already has white needles :)
  17. ssbnreso
    ssbnreso Member
    80
    Have a feeling they might be pink:blush:
  18. S3 Nattie
    1,599
    How does it look at the back for taking the dials out or the bulbs
  19. ssbnreso
    ssbnreso Member
    80
    Easy if your into micro soldering!
    Looks like it would be a bit of a mare!
  20. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Hmmm, mine are really light blue (almost white) as standard?.
  21. ssbnreso
    ssbnreso Member
    80
    Heres the nicght time photo's Remember only done the clock:
    compared to day time:
    As you can see no differance between the needles at night!
    As i said in previous post led's are red hence even with a white needle the red light just reflects off the white needle.
    The only way to get a white needle at night would be to change the led's and as the needles don't have there own individual led's you would need to change them all and then if you wanted coloured numbers and markings you would need some sort of coloured film on the back of the clocks IMO
    Going to do the rest of the needles today (I like the daytime effect anyway) and will have a closer look at the led's and get some phots up.
  22. S3 Nattie
    1,599
    Thanks a lot for that info, very useful. Do you know where I maybe be able to get white LED's for this.
  23. ssbnreso
    ssbnreso Member
    80
    Took the rest of the dials off and had a closer look at the led's:
    The speedo, rev counter, fuel and temp gauges have their own led's:
    Only the clock doesn't:
    but it would be quite easy to make a shroud for these two led's
    You can get the led's from the net ot maplin but what sort they are i've no idea?
    If anybody could tell me what type of led's they are i would be temted to give it a go!
  24. MURRAYS444
    MURRAYS444 Member
    790
    My esp abs and my imobiliser light are very low and there is a place in england that fix the unit if u don't mind not having ur car for a week!!!
  25. ssbnreso
    ssbnreso Member
    80
  26. S3 Nattie
    1,599
    Have you got a link for the exact bulbs you ordered as I dont know which ones to get
  27. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Not the greatest of photoshops as it took me 30 seconds but this is to give you an idea of what it will look like when done.
  28. ssbnreso
    ssbnreso Member
    80
    ordered these ones
    http://www.phenoptix.com/shop/3mm-dome-c-21_35_36.html
    Not sure if there correct but for the price it was worth a punt!
    Will let you know when they come
  29. ssbnreso
    ssbnreso Member
    80
    Ordered blue ones
    thought i'd go for a reversed golf look!
  30. MURRAYS444
    MURRAYS444 Member
    790
    Mate your dials look sweet great mod for not much money!!!
  31. S3 Nattie
    1,599
    Well S3's come like that standard, red dials with whhite needles. Hopefully its possible without to much effort to change the dials to white
  32. Khufu
    Khufu Well-Known Member
    5,704
    31
  33. ssbnreso
    ssbnreso Member
    80
  34. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Yeh I have no idea why I done that photoshop when I could of just taken a photo of my own dials lol.
  35. Westy
    17,440
    1,096
    Your DIS is mullered!
  36. ssbnreso
    ssbnreso Member
    80
  37. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Oh that's really good to what it's normally like as it was cold, when it's warm it's unreadable.
    I'm pretty sure you want these
    http://www.phenoptix.com/shop/plcc2-leds-c-21_30_38.html
  38. sulaiman
    sulaiman Member
    274
    Get some facelift clocks they have white illumination as standard....and you'll get a digital clock and date display.
  39. ssbnreso
    ssbnreso Member
    80
    Well finally got the right led's!
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=360227326526&ssPageName=STRK:MEWNX:IT
    and finally got round to fitting them
    Removed pod and then dismantelled it:
    Needles removed
    White plastic surround just clips off:
    When i got it all apart it bcame obvious that only the rev counter and speedo have thier own individual led's for the needles
    Just changed these four as the others would have also changed the coulour of the face, anyway whats the two most important dials!
    Really quite easy to change led's used this as a guide:
    http://www.youtube.com/watch?v=dotVYFoORUk
    Used my 20 yr old soldering iron not a flash one like his!
    this is the result (daylight):
    Looks better in the flesh!
    Think photo shows how bright white the two dials are compared to the others
    Will get a night time photo tonight!
    Not a bad mod for £2.50:icon_thumright:
  40. Westy
    17,440
    1,096
    Nice work :)
