How to change a cam sensor?
simon rampton May 26, 2013
  1. simon rampton
    simon rampton New Member
    I have a 1998 a4 1.8t avant, and after taking it to audi for a diagnostic and service they said that there are 2 faults which are:-
    THE CAM SENSOR: Is this just a straight unbolt and bolt on job or is it more complicated than that?
    THE WASTEGATE VALVE: Think this is out of my league.
    Any comments and advice will be greatly appreciated thanks.
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    The 1.8t cam sensor is two 10mm bolts and a plug. thats it.... 10min job :icon_thumright:
    It depends what they refer to as the wastegate valve, if its:
    • the N75 (electrical solenoid), fiddly but can be done quite easily
    • the Wastegate actuator, turbo has to come off to change it.
    • the wastegate flap (usually rattles), again, whichever route its turbo off. Either replace turbo, or as i did, find a good condition exhaust housing and swap it.
  3. simon rampton
    The code was N75.
    I'm not too bad with amatuer mechanics but i would'nt say im a professional at all.
    Do you think its possible to fix at home or is it best to take it to a garage,
    A home fix would be better as the garages are very expensive and also its a learning curve.
    Thanks for your help.
  4. aragorn
    17,889
    689
    N75 is an easy DIY fix. Could be a broken wire though, rather than a faulty valve.
