How To - Audi A3 Facelift Halogen Bulb Change
a6_chris Jul 21, 2013
  1. a6_chris
    a6_chris Well-Known Member
    1,883
    160
  2. mjr901
    mjr901 Guest Gold Supporter Audi S3
    3,595
    1,063
    Nice little write up there :)
    Just be careful when you do the 'test' if your in a manual car.
    Someone(there is always 1!!!) is bound to switch the car on in this process and they'll be a little accident with a ruined side skirt and god knows what else.
    Id chock the car, leaving gearbox in neutral, handbrake on. Always try to use flat ground.
  3. a6_chris
    1,883
    160
    Thanks!
    On the facelift cars it won't let you start without dipping the clutch ;) may be different on prefacelift cars tho.
  4. mjr901
    3,595
    1,063
    Very true, was just thinking safety first :)
  5. Zak0123
    Zak0123 Active Member
    540
    76
    Nice write up bud, didn't realise you could access the bulbs from underneath! It's probably worth mentioning as well before you start to give the wheel nuts half a turn loosen when the car is grounded so you don't run the risk of knocking it off its jack when your fighting that initial resistance.
    a6_chris likes this.
  6. Sidhu88
    Sidhu88 Active Member
    808
    76
    I duno about anyone else, but aside from the indicators i've managed to access every bulb from the engine bay. Its tight but it can be done
  7. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Same here, I changed all my bulbs on the front of the car through the engine bay
  8. a6_chris
    1,883
    160
    You both must have small hands!
  9. rennie
    rennie Member
    32
    Yes it can be done, I used a small round vanity mirror (not mine!) and flashlight and just kept looking what I was doing.
    Follow bulb instructions exactly as per manual though!
  10. mjr901
    3,595
    1,063
    You know what they say about people with small hands? ;)
  11. fangio
    fangio Well-Known Member
    1,472
    174
    No - what? :eyebrows:
  12. Sidhu88
    808
    76
    small gloves.
  13. Sidhu88
    808
    76
    Its actually more getting ur hand into the right place. Its made alot easier by the fact the bulb pops in and out so easily, getting it back in is the tricky bit, taking it out is a doddle.
    I'd also advise anyone who is changing bulbs to do both at the same time!
  14. a6_chris
    1,883
    160
    I agree, I changed the passenger side headlight a few weeks ago and this one failed on Friday morning.
    I couldn't get the bulb to release on either side so followed elsa and bingo, far easier.
  15. Aidy06
    412
    19
    No I'm just good with my fingers in tight spaces...
    sliced and a6_chris like this.
  16. Stol1975
    Stol1975 Member
    227
    20
    Ahhh a nose picker are you?
  17. c_w
    c_w Well-Known Member
    1,163
    87
    The clutch lock came in on 2007 so needs clutch depressed to start the car.
    The snap fit of the bulbs really makes it easy to fit them in comparison with other cars that have really ****ty plastic brackets that go over the bulb and required 3 hands to fit unsighted.
  18. a6_chris
    1,883
    160
    sliced likes this.
  19. Aidy06
    412
    19
    Thats what she said...
  20. Sidhu88
    808
    76
    Done this many times. Its not bad when u know what ur doing, its just the process which takes long. U have plenty of space on offside when its all out, nearsides the more difficult one
  21. A13x
    A13x Member
    30
    Is it possible to replace the bulb via the engine bay if your fingers are small enough? It looks like its a twist, remove bulb / power and reconnect new one. Is the cable long enough if you were to go in via the engine bay?
    I recently replaced the BMW lights and had to go in via the wheel (Without removing it) engine bay was a 100% no, power cable, clips were all easy to do without even looking. This audi one looks very similar but not too sure about the power cable once the cap has been removed.
    On another note, if you were to drop the cap is it possible to get it back or does it fall into the bumper?
  22. DervKing
    DervKing New Member
    Nice write up man! Like someone that takes time and effort in these forums! I've got a 1.9tdi a3 facelift and want to change all my yellowing bulbs (H7x4, H11x2 for fogs, and The DRL halogen bulbs too) ...
    Do you know 1. What fitment is the DRL bulbs?
    And 2. Do I have to jack the car up or car I just take the headlights out?
    Many thanks!
