How to: Ambient Lighting for cheap
mikemk4gti Jul 12, 2012
  1. mikemk4gti
    mikemk4gti Member
    122
    I saw a thread where someone had retrofitted an ambient light unit from Audi into his front light, and thought I'd do it the cheap way!
    I've done it before on mk4 golfs (link to my how to guide)
    It was actually alot easier on the A3 as the power is already there.
    Heres the LED's I bought, £1.99 for 5 off ebay seller Phenoptix. (excellent service and good quality)
    So, After removing the interior light I drilled the holes where the marks are.
    Then I had to find a piece of plastic to hold the bulbs, then cut to shape and drill the 2 5mm holes
    Test fitted to make sure they line up
    Then glued into the holder
    I tested them by powering them up to make sure the light shines through the holes ok before I glued it into the lamp
    then wired it up
    Refitted to the car and tested, not a great pic but they work really well
    Took about half an hour to do, and actually cost 80p as I only used 2 LED's.
    Thinking about doing the rear now too :)
  2. mikemk4gti
    mikemk4gti Member
    122
    On to the Rear!
    Just as simple as the front tbh.
    removed the rear light
    Took the switches out for access to drill the holes, marked them then checked that there was enough clearance at the back before I went ahead
    Drilled
    I made spacers up for each led to hold it back inside the lamp, These consisted of a piece of lego I found lying around the house!
    The spacers were glued in, the LED's were a tight fit so I didnt bother glueing them.
    Reassembled the lamp, then checked which feed I was going to link on to, Pin 5 was the switched power from the headlight switch and i earthed it from the aerial base.
    All done, I'll be Out in my car checking them when it gets dark
  3. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    188
    Nice one I may try this it looks really oem good work.
    Chris
  4. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,920
    756
    looks really simple, i may have to think about doing this myself after i sort out my air vent boost gauge (which i brought 6 months ago, and is still in a box right beside me, where it has been since the day it turned up...)
    EDIT: and thanks for the photos, always makes more sense with photos
  5. mikemk4gti
    mikemk4gti Member
    122
    Yeah, really is simple and v cheap mod too.
    I tried them last night and the fronts are great, I need to adjust the angle on the rears so they point slightly more forward though. Might not be a problem if you've got black leather but on the silver/ivory it stands out a fair bit!
  6. Lacee
    Lacee New Member
    17
    It looks really original! No idea what was the reason why you made it but it looks good! :arco:
  7. g60jet
    g60jet Member
    145
    for the front you could of just purchased 8E0919063A and drilled two holes!
