How to add a computer and cruise control?
blanc May 12, 2011
  1. blanc
    blanc Member
    47
    Hi All
    My quattro did not come with either a computer or cruise control. How do I fit same and is it expensive?
  2. hades-
    9,481
    646
    or you can search theres plenty about it on here
    easy to do yourself
  3. blanc
    blanc Member
    47
    I didnt find any one the computer, just adding cruise control off of ebay job. Any suggestions
  4. Jama665
    Jama665 Member
    202
    search retro fitting dis (driver information system) should pull up something.
  5. blanc
    blanc Member
    47
    It pulled up your reply,lol. Any suggestions or could someone post a link? I admit my PC skills are not great!
  6. mlody
    mlody Member
    184
    Where do you live? I could give you a hand if you need
  7. Jama665
    Jama665 Member
    202
    Try a search on google for something like "retro fitting dis to A4 B6" That will bring up something I would guess. Not had to do it myself but Googles good for trouble shooting.
  8. jbcalvin
    jbcalvin Member
    691
    21
    You'll need new wiper stalk with DIS control, cruise control switch, new lower steering column trim and a compatible steering wheel control module.....
    once fitted, VAG-COM to code everything in...
    Oh and if you probably won't have a low washer fluid level sensor, so you'll need to either fit this, or ground the correct wire from the dash panel...
    Just got mine done...
