How thirsty is your S3 on oil ?
ex_scoobydoo Dec 9, 2009
  1. ex_scoobydoo
    ex_scoobydoo Member
    179
    i had a service almost 3 weeks ago and already i have had to top up with another litre of oil, i have no leeks etc and it doesnt seem to be burning oil from the exhaust, this cant be right ?
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    No that doesn't sound good! Mine uses a very small amount over a year as you'd expect but I dont cover any more than 9k miles a year.
  3. S3LOV
    S3LOV New Member
    24
    Doesnt sound to healthy.....ive had mine for a month now and hasnt lost any ......trip to a garage i think..:think:
  4. ex_scoobydoo
    ex_scoobydoo Member
    179
    i have seen on other forums some audis do use a lot of oil around 1 ltr per 1000km that is around 650 miles correct ?
    i have probably coverd that milage in around 3 weeks tbh
    were else could it be going i cant work out, no leaks not burning oil, from what i can see anyway, strange.
  5. Dani_B19
    9,253
    378
    Tbh mine does like its oil but its no way near that firsty.
  6. ex_scoobydoo
    ex_scoobydoo Member
    179
    well i have noted the miles and level, will keep an eye on it
  7. pauldazzle
    pauldazzle Well-Known Member
    1,166
    87
    Did you check the oil level when you got it back from being serviced? It's possible that they underfilled it. I'd just keep a close eye on it for a while.
  8. Ian W
    Ian W Active Member
    1,058
    12
    I've had to top mine up once or twice but I do alot of miles. Sounds like the garage that did the service didn't top it up enough.
  9. 5ean
    5ean S3 Owner VCDS Map User
    415
    Mine also likes a fair bit of oil.. No leaks either and no smoke from the exhaust.. Where would you start troubleshooting? Dont want to go looking for a problem that doesn't exist if it does just like oil??
  10. golf
    golf ***** rent boy VCDS Map User
    1,556
    It's very possible that the people who serviced it, didn't fill it up to the required level. Just keep an eye on it in the next 1,000 miles.
  11. sportquattro
    sportquattro Active Member
    835
    51
    In just under 3000 miles I've had to add less than a 1/4 of a ltr, my previous A4 1.8T Sport would use about 1 ltr every 2000 miles or so.
  12. sammi
    sammi Active Member
    345
    45
    That isnt good, have you checked in the intercooler pipework that oil isnt getting in there sounds silly but if oil is passing through the turbo seals then there will be oil residue in the intercooler pipework. you wont necessarily notice it unless you get a mate to drive behind you and check for blue smoke on boost.
    High revving engines tend to burn a little oil due to oil pressure and temp however that is a lot in that amount of time especially if its been driven sensibly.
    Our skyline is very highly strung and that uses no oil even under immense pressure like racing round the ring in 35 degree temps so I would start some self diagnosis to put your mind at easy and to sort any issues out before more lasting damage is done.
  13. ex_scoobydoo
    ex_scoobydoo Member
    179
    i have noticed a little oil residue in Induction Hose just before the MAF
    could this be the seals in the turbo on the way ?
  14. Dani_B19
    9,253
    378
    No, thats the PCV system dumping oil back into the TIP.
  15. MIKE GTR
    MIKE GTR Member
    366
    Maybe they put a really low viscosity oil in, check that 1st. My main diagnosis would be he one already suggested several times that u seemed to have ignored, they underfilled it at the service and checked the level cold without starting it first and turning off and rechecking - ignore the gloommysters and check the obvious first
  16. ex_scoobydoo
    ex_scoobydoo Member
    179
    yer sorry i overlooked the part about underfilling, i was there when the service was done, by a friend, oil level was fine, i did use coma 5w 30 semi synthetic, as i plan on service every 6-7000 miles, i guess all i can do is keep an eye on it, maybe try better oil next time
  17. sammi
    sammi Active Member
    345
    45
    You would presume that a competant garage would check this before letting a car go back to a customer but I agree that would be the best place to start and see if you loose the same oil in a similar period of time.
    Not trying to be gloomy and I really hope there isnt a problem its better to spend some time checking simple things like smoke, oil residue etc to avoid spending lots of cash with a garage or do any lasting damage, only trying to help but I am no mechanic just learnt owver the years with various high powered supercharged VW's and Turbo charged ricepods.
  18. joppydan25
    joppydan25 New Member
    hi mate i had the same problem! got my car serviced at a local garage! didn't do it properly! go to audi ask for a long life service. good luck.
  19. barters3
    barters3 Member
    438
    Sorry to pinch this one....
    i noticed the other day that one of the pipes connecting to my dump valve has leaked slightly oilly air. (it is what i presume is the inlet to the dump valve. the oposite side to where it connects to the TIP.)
    im going to replace the clip and inspect the hose for damage.
    I was just cocerned that the air escaping was oilly, is this to be expected?
    Any advice apreciated.
  20. ex_scoobydoo
    ex_scoobydoo Member
    179
    is thier a certain procedure on how to do an oil change on audi ?
  21. barters3
    barters3 Member
    438
    i dont think there is anything different about the changing method. when i had my oil change done my mechanic let the oil drain longer than he normally would have as he was checking something else on the car. when he topped the oil back up it actually took nearlly 5 litres where as it normally takes 4.5.
  22. S3KO4
    S3KO4 Member
    850
    like all said here they didnt top up enough and my engine burns around 1liter ever 1.5k on a fast drive but I have asked many garages and it is apparently normal
  23. 5ean
    415
    I'm using about a litre every 1.5k also.. A mate of mine who used to work at Audi said they can use a fair bit of oil but perhaps not as much as what im using. I've had a mate follow and there's no smoke, and defo no leaks.. Surely if the seals in the turbo were gone the oil level wouldn't drop that quickly would it? One would expect to find some effect from broken turbo seals? Other than oil loss that is..
  24. alijames
    alijames Active Member
    1,024
    I do an oil change every ~5k, and never need to top up more than once in that time, and not more than ~1/4 litre.
    Cheers,
  25. pauldazzle
    1,166
    87
    I think you need to check that the intercoolers are clear of oil. Oil could be collecting there. Wouldn't neccessarily give you a smoking exhaust as it won't be burning off.
  26. 5ean
    415
    So if there is oil in the intercoolers then the seals on the turbo are gone? Is this just a case of new seals or is it a new turbo?
  27. pauldazzle
    1,166
    87
    I think a small ammount of oil in the intercooler may not be a cause for concern, but if there's a lot, that's not good at all.
    I think you can get the turbo seals replaced.
  28. whatstandwell
    whatstandwell New Member
    I've put 1 litre in my S3 over the last 6000 miles.
  29. jojo
    28,882
    3,537
    I've not had to put any oil in my S3, and I did 9k miles or so over 2 years before I serviced it myself, using the correct VAG spec oil, Quantum Gold or something similar.
  30. barters3
    barters3 Member
    438
    it is stated in my handbook that it may burn upto 1 litre per 1000 miles.
    mine uses about 1 litre every 2500 miles. just keep an eye on your levels, you will soon get to know what is normal for your car and then you can spot major drops.
  31. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
    Im servicing mine every 5k with Quantum Gold and OEM filters. I dont have to top mine up as when 5k comes around I service her again :kissmyrings:
  32. thegoal007
    thegoal007 Another S3 owner....
    804
    26
    I've had the car about 2.5 years and covered about 6k miles. oil level exactly where it was 2.5 years ago. Mileage covered is either very short journeys in town and half way round m25 journeys.
    erm, that reminds me time for an oil change ! BTW, the last oil change was a long life one.
  33. crunchie
    crunchie Active Member
    880
    77
    with an oil consumption like that you'll never need to service it! Lol. Service mine every 7k as its mapped, uses 250mm in this time TOPS!
  34. ex_scoobydoo
    ex_scoobydoo Member
    179
    update
    so 3 weeks later and 600 miles again another ltr of oil is needed
    as before no oil leak, car seems to be running nice, no burning smoke or oil from the exhaust, i do need i new first lamba probe but i doubt this is the cause.
    no other faults on vag com, so suggestions or ideas please guys
  35. Westy
    17,443
    1,103
    If I was you mate I'd save yourself the hassel and just get it checked over by a VAG specialist. By the time you've gone through a few of our guessed suggestions you'll be another £40 down in oil costs!
  36. ex_scoobydoo
    ex_scoobydoo Member
    179
    yer true, a friend of a friend just said lamba probe! it will be getting to hot and burns oil, funny enough vag com said i need a new 1st lamba, the guy didnt know this, it was just the first thing he said, so maybe could be the cause, but @ £90+ will be the new year now before i buy one, but ill update once i have :)
  37. Westy
    17,443
    1,103
    I think you'll be best getting yourself one then mate. VCDS is normally very accurate.
