How similar are an s3 and cupra engine bays??
nath-w Jul 13, 2009
  1. nath-w
    nath-w Member
    141
    Just wondering if anyone knows if an air intake heat shield out of a seat leon will fit properly in an s3??
  2. RichA3Turbo
    5,089
    Heat shield for an open air filter? if so dont waste your money.
  3. RichA3Turbo
    5,089
    But to answer the question, it SHOULD fit perfectly.
  4. nath-w
    nath-w Member
    141
    Do you really think it would be a waste of money. i want an uprated air filter, but thought that just sitting say a K&N cone air filter in there would mean that it would just suck in all the hot air from the engine??:hi:
  5. RichA3Turbo
    5,089
    even a heatshield wont do the job, and the OEM airbox is more than ample for standard and even chipped S3 power. if its power you are after, you will gain nothing from a filter. What i would do is put in a new filter, and get a decent cold air feed going into the airbox from the bumper.
  6. RichA3Turbo
    5,089
    But if you really want to go down the CAI route, i would suggest a BMC CDA....Its completely sealed, but dont expect any real power gains.
  7. nath-w
    nath-w Member
    141
    oh rite. i only really started looking into it, as i recently found out that the previous owner has drilled lots of holes in the standard airbox thats in there now, and i thought the car would run a lot better it its sucking in cold air.
    would an open air filter make the engine noise a lot louder, and sound a bit boy racer?? if so i mite just look into getting a new standard air box, one without holes in it!!
  8. IIIadidasboy
    IIIadidasboy Member
    312
    Yeah it'll make a bit more noise, but as Rich said, if you're sucking-up more warm air then you're going to lose power - sort of defeats the object
  9. RichA3Turbo
    5,089
    Yeah a open cone sounds pretty **** to be honest. Too much turbo noise really.
    Replace with a new one, get a good cold air feed going to it and a new panel filter and be done with it.
  10. IIIadidasboy
    IIIadidasboy Member
    312
    Rich, I know a few years back you were playing with a cone filter mounted inside a modified air box - how did that work out in the end?
    Reading you posts I'm thinking you went back to standard box with a cold air feed?
