How should the front arch liners sit?
Bad Sir Culation Dec 31, 2013
  1. Bad Sir Culation
    Bad Sir Culation Member
    287
    17
    Mine weren't properly attached. Should they sit with the lip from the bumper over the top of them, and the liner tucked in behind it, or vice versa?
  2. epox
    epox Active Member
    774
    74
    Arch sits behind the lip on the bumper.
    Mark
  3. Bad Sir Culation
    287
    17
    Cheers, I thought so. Unfortunately the holes on mine don't seem to line up very well with the holes on the bumper.
  4. Broken Byzan
    13,237
    465
    they never do, they arch liner sort of needs to be pushed up and into the bumper corner to line up. Also make sure the speed clips are in place otherwise it will never do up
  5. Bad Sir Culation
    287
    17
    Speed clips?
  6. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    The metal little clips that the screws will screw into.
    Looks like these-
    U Nut Speed Clips Pack 10
  7. Bad Sir Culation
    287
    17
    I thought you probably meant those :)
    I need some more of those. Do you know if I can get them anywhere on the high street?
  8. kwistof
    2,434
    535
    First all I'd call up TPS and see if they have any they could sell you?
    But your best bet would be to take one off, pop down to your local B&Q, screw fix etc and get them to match it for you.
  9. Bad Sir Culation
    287
    17
    Managed to find a pack of mixed sized ones at Halfords but they are a rip at £7.99. I'm going to see if I can find any A3/S3's at the scrappers after the New Year first as I need a couple of little bits.
