How should my car feel?
Audi_A31.8T Jan 30, 2014
  1. Audi_A31.8T
    Audi_A31.8T Member
    92
    Ok just got an a3 1.8t it's not what I was expecting doesn't feel like it should if that makes sense
    im used to driving a diesel which was running at about 150 bhp obviously the derv had more torque but my a3 feels a little sluggish
    it looks fairly standard vcds has been bringing up lambda sensors would this cause poor performance?
  2. robin_bga
    robin_bga Member
    50
    Hi, it affects consumption problem being unbalanced.
    Drive it really hard then hook up the vcds again & see what it gives you.
  3. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    Scan it with vcds would be my first call
  4. Audi_A31.8T
    Audi_A31.8T Member
    92
    Address 01: Engine Labels: 06A-906-032-AUM.lbl
    Part No: 06A 906 032 DK
    Component: 1.8L R4/5VT 0001
    Coding: 11500
    Shop #: WSC 00647
    VCID: 6ADB242A16DFE44E2A7-517A
    WAUZZZ8LZ1A025983 AUZ7Z0Y1572803
    4 Faults Found:
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1116 - 35-00 - Open Circuit
    17608 - Boost Pressure Control Valve (N249)
    P1200 - 35-00 - Mechanical Malfunction
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 35-00 - Performance too Low
    17522 - Oxygen (Lambda) Sensor; B1 S2
    P1114 - 35-10 - Internal Resistance too High - Intermittent
    Readiness: 0010 1101
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 E
    Component: ESP FRONT MK60 0103
    Coding: 0019970
    Shop #: WSC 06435 000 00000
    VCID: 2C57E2328CAB3A7E18B-517A
    1 Fault Found:
    01423 - Lateral Acceleration Sensor (G200)
    012 - Electrical Fault in Circuit
  5. robin_bga
    robin_bga Member
    50
    N249 is where your problem is
  6. robin_bga
    robin_bga Member
    50
    The O2 sensors need replacing however I feel its better you first erase them drive the car then scan to see if they come back.
  7. JimS3
    JimS3 Active Member
    736
    72
    150bhp petrol will feel more 'flat' than a 150bhp diesel.
    My old A4 1.8t felt like you were always waiting for it to get going compared to my golf GT TDI with the same power.
  8. Audi_A31.8T
    Audi_A31.8T Member
    92
    the n249 has been removed which ive heard is a common thing people do? i have cleared the codes and they come back every time! where is the 02 sensor ?
  9. Audi_A31.8T
    Audi_A31.8T Member
    92
    but yes jim i need a remap any advice on it ?
  10. robin_bga
    robin_bga Member
    50
    O2 sensors are located on the exhaust system & yes if those components were removed then a remap is necessary.
  11. JimS3
    JimS3 Active Member
    736
    72
    Yes remap for sure.
    Plenty of remap info in the stickies, but my personal recommendation would be Revo if your leaving the rest of the car fairly stock or badger 5 if you get the modding bug.
    Plenty of companies to choose from though, you pays your money and takes your choice!!
    sssline likes this.
  12. Audi_A31.8T
    Audi_A31.8T Member
    92
    will look around thanks what sort of gains would i be looking at from a stage 1 map?
  13. JimS3
    JimS3 Active Member
    736
    72
    N249 can be bypassed vacuum wise, but not removed. If it's not electrically connected, that's why it's throwing a fault.
  14. JimS3
    JimS3 Active Member
    736
    72
    Bout 195 bhp and the same torque as a 150bhp diesel :yes:
  15. Audi_A31.8T
    Audi_A31.8T Member
    92
    thats better
    i think the n249 was a bit of a bodge
    ive only just got the car so trying to resolve the issues before i start tuning
  16. robin_bga
    robin_bga Member
    50
    So u are the same person trying to get the hanging sockets right?
  17. Audi_A31.8T
    Audi_A31.8T Member
    92
    yep lol as said new to 1.8t and this car so need sorting out! will have the weekend to have a good look at it
  18. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
    where abouts are you from? im in the cardiff area of south wales
  19. Audi_A31.8T
    Audi_A31.8T Member
    92
    Just down the road then mate I'm just off juc 27
