How often should my pd be serviced ?
dale86 Mar 20, 2013
  1. dale86
    dale86 Member
    436
    14
    Hi was just wondering how often my pd130 engine should be serviced it has a full service history at intervals of about 12,000 so ive just been sticking to that had car 2 years now so am i servicing it enough. Thanks Dale
  2. cnut
    cnut Member
    153
    9
    I tend to go every 10000 miles or 12 months, whatever comes first.
  3. dale86
    dale86 Member
    436
    14
    Yeah thats what I tend to do evry 12 month which works out about 12,000 miles and its when the service light comes on at about the same time too
  4. SL11CKK
    SL11CKK Active Member
    694
    35
    Call me crazy, but I oil service my car approx every 8000 miles which includes air filter too and the next service after that I include diesel filter on the list.
    Funny thing is I only do approx 1200 miles a year. So end up doing the service every year December/January
  5. chris1008
    chris1008 Member
    118
    In the book and on the car display it is 10,000 miles or a year on fixed servicing, which is loads better than long life schedules cocking everything up with the oil inspection and time inspection reminders.
    Think it's 15,000 on long life services, but that needs special oil to be in there that long.
    I stick to old fashioned once a year full service and oil and filter every 6 months, have done on my petrol cars. But as I run the car on bio diesel now I will also be doing the fuel filter every 6 months, it has pipercross panel life time filter in so it's practically a full service every 6 months.
    I probably do about 10,000 miles a year, if I was doing 1200 miles a year I would be more inclined to just stick with the annual full service and skip the oil changes in between, the oil is still like new !
  6. deano1978
    deano1978 different gear
    713
    81
    I do about 20k a year.
    So more is better, services,for me anyway.
    I tend to service mine about every 5-7k.
  7. T0m
    T0m Active Member
    516
    26
    10k or 12 months whichever comes first
  8. dale86
    dale86 Member
    436
    14
    Well mines been gettin it done about evry 12k once a year on the mileage I do which is around 12k a year so ill stick with that thanks for the replys.
  9. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,731
    653
    5K or every 6 months for oil & filter, and getting the stuff from TPS makes the cost around £30.
  10. RobMorris
    RobMorris Member
    539
    10
    As mine is on nearly 200k, I do Oil and Filter every 3000 miles/3 months.
    Although ive only owned the car for a month and already done a full service + a 2nd oil change!
  11. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I don't bother servicing.
    At the end of the day, oil is good nowadays compared to decades ago so lasts a long time.
    Done 40k in the car since I owned it and not changed the oil/filters, oil level has barely budged too - its just over the minimum mark.
    Even if it reads below the minimum there should still be enough oil in there.
  12. Wahlstrom
    Wahlstrom Active Member
    399
    144
    43
    The added stuff in the Oil wears out... Yes the oil is better today than years ago but You still need to change it, regardless of consumption
  13. AlexGSi2000
    1,464
    199
    Sorry - I was just taking the mick.
    I change mine religiously every 7,000 miles. 5-40w fully synthetic for me.
  14. Mike.M
    Mike.M Well-Known Member
    2,484
    169
    Every six months for me on all cars
  15. dale86
    dale86 Member
    436
    14
    So am i leaving it too long as this 12k roughly seems to be the lenth between each service its had even from audi dealers at the beginning of the service history or is it just personal preferance ?
  16. Mike.M
    2,484
    169
    I always do 6 month or 5k mile oil changes (which ever comes soonest)........then on the annual one it gets the usual air filters etc
  17. B5NUT
    3,731
    653
    You may be joking but I knew someone that never serviced their car in 3 years, engine packed in on the 4 year as the Oil was like tar. I asked her when it was last service, response back was "I got the car from new why did I need to service, that's just for used cars" [​IMG]
    RobMorris likes this.
  18. cnut
    cnut Member
    153
    9
    I have an uncle that runs a 1.6 Escort. A few years ago I was talking to him about cars, saying how often I service my car etc and to my amazement he said he had never changed to oil once in the Escort since he owned it, it's been topped up but never changed. He must have owned the car nearing 10 years at that point and as far as I know it's still running now! And no he isn't the type to BS!
  19. audilad9
    audilad9 Member
    257
    I do my AVF engine oil and filter every 5k miles, always have done. Fuel filter once a year before winter to prevent problems with cold and air filter is K&N gets clean and oil then too. I also do pollen filter annualy as its so cheap and easy.
    I have an ECS magnetic oil drain plug. Gets a clean when out.
    I buy genuine filters from ebay Audi dealer, a lot cheaper.
    I buy platinum oil from local Audi stealer, havent seen it anywhere else ??
    What does TPS stand for ?
  20. AudidriverA4
    AudidriverA4 Member
    183
    Oil and filter changed every 5000 miles here too.
    Fuel, air and pollen filters changed once a year/20000 miles.
  21. Mike.M
    2,484
    169
    I get all my bits from TPS. They are the VW Group Trade Parts Specialist and basically supply the main dealers with the original parts
    To buy direct the majority require you to be in the trade.
    audilad9 likes this.
  22. Springer*
    Springer* Member
    169
    17
    Like anything, its all subjective..
    It depends on how you drive the car, how often, what kinds of journeys, does it get fully warmed up each time etc..
    I'd generally service it every 10-12k miles or once a year, whichever comes first. At the end of the day, you can't really change the oil too much, and running the car on nice fresh oil all the time will be good for it. However, changing the oil every 12 months or 10,000 miles won't hurt it as modern oils are generally pretty good.
    I seem to remember that on the B6 1.9 engined cars the long life services were every 18,000 miles and this has been proven to be too long and can cause wear in the engine, so I'd make sure it serviced more often than that.
    As far as the air filter is conerned, they're only cheap so it doesn't hurt to change them each time, though if it were me I'd just make sure it was fully cleaned up every six months and changed every 2 years.
    The fuel filters do clog up too and so its worth keeping on top of those.
    J
