How much to fix my cruise control
zollybosher Oct 30, 2012
  1. zollybosher
    zollybosher Member
    58
    basically stopped working if you move the stalk or try to set nothing appears on the console and nothing happens with the speed. What @ cost am I looking at to get it fixed - worst case scenario. Not technically minded so please don't ask me to check switches etc Just need an idea of the cost involved for repair..
  2. kite
    kite Member VCDS Map User
    677
    Depends on what is broken, could be as simple as brake/clutch switch failed.
  3. zollybosher
    zollybosher Member
    58
    Worst case scenario, as I have no way of checking/fixing it myself
  4. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Most likely problem is the clutch switch, which only costs a few £ (<10) and takes less than 15 minutes to fit yourself.
  5. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    +1
    Done plenty of fits to find the clutch switch is faulty. I always carry a spare clutch and brake switch to jobs with me now as I have come unstuck a couple of time, lol.
    The clutch switch especially is very common to go faulty on the B7.
    Part cost around £14 and a quick fix, but best bet is find someone local with VCDS to check the measuring values of the clutch and brake switch.
    Where abouts are you mate, maybe I can help assist you, I am in North London if any good to you?
  6. ben.w93
    ben.w93 Member
    213
    22
    Remove the clutch/disconnect the cltch switch and connect the two wires together to see if it is a faulty switch, it just means connecting the two wires together, cruise control will not disengage by pressing the clutch switch, thats how I tested mine when it broke.
  7. zollybosher
    zollybosher Member
    58
    Can this be done by myself or do I need certain equipment to check values etc --IF it can be done by myself can someone provide a guide or link to one?
    Thank's
  8. Dannykn9
    1,123
    56
    Honestly mate, it is such an easy fix.
    Quick guide:-
    1.Remove fuse side panel.
    2.Remove 1 x 8mm bolt
    3.Remove 2 x 8mm bolt under panel.
    4.Remove connector from clutch swith
    5.Turn clutch switch anti clockwise and remove (remember the way it came out)
    6."Before you install new clutch switch, pull plunger all the way out, press clutch pedal down, re fit the new clutch switch, slowly depress clutch pedal so the plunger finds its own level.
    7.Reconnect the connector.
    8.Put the panel back on.
    Job done :)
    If you honestly don't feel comfortable doing it, then as already asked, where are you as I am sure there is someone local on here who can help you out.
    Seriously mate, not much any of us can do. Plus thought you would have fixed this by now as I am sure you started a different thread back in August???
  9. PetrolDave
    1,559
    85
    No need to do this step with the alternative clutch switch that Audi supply now (7H0 927 189) - just push the new switch in and turn until it locks.
  10. Dannykn9
    1,123
    56
    Although your right Dave, I have had a couple of the new revised switches that I needed to pull the plunger out, as the plunger was too far in.
    But yes, if already out, then no need to pull out any further.
  11. matten22
    matten22 New Member
    10
    Hi dave im having the same problem with the engine holding onto its revs inbetween gear changes, sure its this switch, do you where is best to order it from?
  12. Dannykn9
    1,123
    56
    Best place to order one is from your local Audi dealer.
  13. PetrolDave
    1,559
    85
    +1
    It's a common failure item so they'll probably have it in stock.
  14. matten22
    matten22 New Member
    10
    ill give them a ring in the morning thanks , fingers crossed it sorts it so i can unleash the full potential of the car :)
  15. Luke2.0tdi2010
    Luke2.0tdi2010 Active Member
    287
    50
    I had same thing, I had owned the car for about a year and a half without the c/c working only to realise it was a £15 job that took me 10mins to fit, and I'm a TOTAL novice when it comes to anything to do with fixing my car! I followed a step by step guide, don't seem to be able to upload pdf files here but can email it to you if you want.
  16. matten22
    matten22 New Member
    10
    Cheers guys, it was just as easy as you said. took me 10 minutes , very easy job and totally fixed the issue :) you would be mad to pay a garage to do that for you !
  17. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    What did you mean by pulling the plunger out if you don't mind me asking. I replaced my original clutch sensor switch with this revised model and the cruise control now functions however I'm getting the same issue as mentioned below with the revs holding between the gear changes.
    Is it just a matter of pulling the plunger further out to detect the pedal being pressed sooner?
    Thanks, Az.
