How Much Should The Actuator On the VNT Turbo Move..
Mackers Feb 25, 2012
  1. Mackers
    Mackers Member
    291
    as above, did an oil change today and thought i'd see how much movement i had and if it was sticking.... it was a little stiff, but not too bad i recon (cleaning the turbo with the "mister muscle mod" left for another day) and i was managing to move it about 7-9mm ish and it wasn't "wobbling" (which i been told is a good thing)... is this 7-8mm movement right??
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    My AFN diesel had about 10-15mm of "extension" when it was mullered.
    About 7-8mm was roughly what the new one had.
    Mackers likes this.
  3. Mackers
    Mackers Member
    291
    sounds good to me then :D
  4. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    If you have a look, you will see a screw stop for the actuator.
    The actuator should move to the stop.
  5. Lion Garage
    Lion Garage New Member
    24
    Best way to test is with a VAC pump (I use a Mityvac) Draw vac on the actuator then find a way of pushing/pulling the lever to see if it has reached its max (should be a reasonably solid feel if it has) and wont push further. Then release the vac and check the lever returns quickly and smothly back to the min stop in the same way. If its sticky at either end and doesn't easily and smothly move to the limit stop you have issues brewing.
    HTH
    Steve.
