How much oil do i need
taztam May 15, 2011
  1. taztam
    taztam New Member
    10
    Hi everyone
    I have tried the search section but couldn't find what i am looking for and have checked my book in the car.
    I picked up my A4 avant 1.8t 190 Sline yesterday and decided that i shall do an engine flush and new oil. Car has been on longlife since new and will be changing that to 6month oil changes.
    How much oil does the 1.8t take?
    If there is a post can you post the link and i will have a read
    Cheers for your help
    Tam
  2. crazypainter
    crazypainter Member
    593
    pretty sure you'll get change from a 5 litre can.......
    But wait for confirmation !
  3. mrjheeta
    mrjheeta Member
    337
    i was told the other day its 3.5L, but my engine is an AVJ.
  4. simon.m
    simon.m Active Member
    2,747
    haynes manuals says if its a 1.8 and you put a new oil filter on its 3.7 litres if its a 2.0 then its 4.2 litres
  5. Alan H
    Alan H Need a V8 or Bi-Turbo.......
    457
    AVJ is definitely 3.5l (well just over)
    I wouldn't have thought it would differ much. I would assume the engine codes are to do with bolt ons such as turbo, pistons???
    The capacity won't differ much from engine to engine I wouldn't think.
  6. taztam
    taztam New Member
    10
    Cheers for that everyone
    Do i need fully of part synthetic?
    As i went to Adi and they said if i am going to change my oil every 6months you will be better off with the part synthetic. It meets the vw/audi spec and is 10w40 or should i have gone for the 5w30?
    Tam
  7. Tooks
    Tooks Active Member
    753
    29
    Always use full synth in the 1.8t, false economy otherwise.
    Also, ask your Audi parts depot or GSF for the oversize oil filter (from a VW Van I think!), it will take the oil capacity up from 3.7 litres to nearly 4. Every little helps!
    Personally, after flushing my engine with Wynns and then changing my oil, my oil pick up pipe became blocked a few miles later. I would strongly advise not doing it, I believe the flush dislodged loads of sludge etc which then blocked the pick up strainer.
    Best advice is to change the oil more frequently for a while so that the new oil with it's detergents gradually cleans up the engine. I do mine every 6000 or 6 months now, but it won't hurt to do a couple of changes at 3000. Full synth 5w/30 is what you need.
  8. simon.m
    2,747
    have to agree with tooks on the not using oil flush stuff iv looked into this a few times and its not the best way to clean the old oil as like he says it dislodged a lot of **** that the car has bilt up over the years and needs some of it still as the engine has worn any how i was advises to drop the old oil put new in drive it for a mth then drop it again and put new in oil in job done i thought this would be a wast but did it and seems to clean it nicley so will keep on doing it this way as i was told the new oil will brake down the **** on its own that why you drop it a mth latter
  9. T0m
    T0m Active Member
    516
    26
    Simon do you change the drain plug each time you change your oil? and do you know the part number as Im going to do my service myself dont want to pay audi £270ish when I can get all the parts from my mum who works for a car spares company for under £100 and do it myself!
  10. crazypainter
    crazypainter Member
    593
    I also agree with not flushing, but doing regular changes at 6 months. The 1.8 lump needs this regular change........Happy motoring.!!
  11. simon.m
    2,747
    yes mate its only 2 pound or some thing i dont have the part number for it mate but id get it from audi any way as they keep them in stock where abouts are you
  12. T0m
    T0m Active Member
    516
    26
    Tis ok fella my mums place also stocks them just wasnt sure if you change the oil after a month to bother getting one then again they are peanuts so it dont matter.
    Im in Lichfield fella!
  13. simon.m
    2,747
    oh sorry mate miss read no not for the mth change no i dont i use old one for the mth then when i change it for the main sirv i put a new one in
  14. MDA
    MDA sploorer
    87
    p AN 013849 2 is the sump plug seal unit price 46pence
    p A068 115 561 F is the large oil filter unit price £9.50
    from leicester Audi
