How much boost could K04 puff, if K04 could puff boost? :-)
AFDanHef Jan 10, 2013
  1. AFDanHef
    AFDanHef Member
    75
    LOL I have an '03 S3 and I've seen the thread on the K03 but I was wondering can I get 300bhp out of my K04? I have a FMIC setup, I just ordered a Badger 5 Tip and Neuspeed P-flo filter. I am going to do a full exhaust (turbo back decat) and then a stage 2 tune. Will I be able to reach my goal of 300bhp out of this setup? If not what will be the limiting factor? I would think the K04 would run out of puff but not sure.
    I would do a search of the forum but the search is screwed up right now so does this justify me in asking flaming questions?
  2. Broken Byzan
    13,237
    466
    have a peek at Westys build thread for ideas, suffice to say 300 is possible if you want it hard enough
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    exhaust manifold is the limiting factor
  4. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    As above you will need a healthy ko4 and engine, a relentless manifold, relentless 3in dp and after market exhaust, b5 tip, wmi, 440cc injectors, 3in inlet and outlet fmic, Jetex cone, heat shield for cone, n249 delete, catch tank then you will be close to 300 bhp, mines off to be mapped in 3 weeks I'm hoping for 290 with a similar set up :)
  5. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    To answer what you said, weld the wastegate shut and find out
  6. Sam_
    Sam_ Down under
    3,038
    480
    No where near as much as the newer K04 clearly :(
  7. beachbuggy
    1,931
    202
    where you off to for the map? You should easily see 290bhp
  8. AFDanHef
    AFDanHef Member
    75
    Miller what do you think of the Relentless manifold? How does the build quality look and feel?
    I have to be skeptical of the quality of something from ebay ... especially tubular manifolds.
  9. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    Relentless is the best.
    Phil is going to R Tech.
    Read Westys thread, IMO that is the most complete K04 setup I have ever seen.
    Westy likes this.
  10. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Once you have all the necessary mods, the limiting factor will be your turbo. Westy made 300bhp on a very low mileage turbo and had WMI, as well as one of the first TIV maps around..
    I made 290bhp, then 290 again with a large port head, large inlet mani and 70mm TB. The turbo wouldn't flow anymore. With more timing 300 may have been achievable.
    What I am saying is just because you have the mods required, the turbo does have a limit.
  11. AFDanHef
    AFDanHef Member
    75
    That's about what I figured. I have been sifting through Westy's thread but 84 pages is a lot to go through. The search is fixed now so that will help some. I could be happy with 290 bhp. I didn't want to spend the money on a turbo but maybe someday in the future.
  12. Westy
    Westy Well-Known Member
    17,443
    1,105
    Start from the last page and work back mate. It's all a bit slow at the start of my thread ;)
    I still think I could squeeze a bit more out of my setup with a bigger TB and inlet manifold.
