How much and which oil for my 2.0tdi?
Gates Oct 7, 2012
  1. Gates
    Gates Member
    139
    I've tried doing a search on here but it just comes up with hundreds of unrelated posts as I think it seperately searches each word you type in.
    All I'm wondering is how much oil will I need for an oil change on my 2.0tdi and which grade am I after please as I'm thinking I may buy all the bits I need to service the car at the same time as buying my clutch.
    Many thanks
    Gates
  2. Josh84
    Josh84 Member
    74
    Hi, i put the same post on a few days ago for my A3 2.0TDI, got the below response from a guy called SAiLO, not sure if the engines the same but there aa discount code that could be handy to you.
    I use Shell Helix Ultra Extra 5w30 (you can get Castrol Edge or any other brand). When you drain the oil completely 3.8 liters should go back in.
    By the way, you can use 'OILSPILL30' code at eurocarparts.com to get 30% discount. ​
  3. i_786_i
    i_786_i Member
    60
    Hi,
    For a 2.0TDI, you need 3.8ltr when changing oil including oil filter.
    5w-30 recommended (Castrol EDGE FST)
  4. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,499
    3,059
    I think this information is in your owner's manual.
  5. chrisa4quat
    chrisa4quat Active Member
    970
    29
    Any 5w30 should be fine. If it uses a bit between services you can change it to 5w49 but this is not long life oil
  6. Gates
    Gates Member
    139
    Thanks for all the help people, I know it's in the owners manual but I'm working away and trying to get he bits ordered for when I get home :) so is the 5w30 long life oil then? Im going to start changing it more regularly now anyway as the car has done 125000 so don't really fancy leaving the oil in longer than I would a normal car.
