How many problems with DV valve after map ?
Gfermer Oct 1, 2013
  1. Gfermer
    Gfermer Active Member
    454
    72
    As above just getting a stage 1 map with cai and miltek in couple weeks just wondering how many of you has had to upgrade the DV valve ? If that's the correct part I'm thinking of as I had to upgrade my recirv valve on my Vxr after it was mapped as the standard rubber 1 was prone to tearing, I'm not great with cars so please bare with me if I'm confused I'm learning tho haha
  2. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Mine had gone before the map. Worth checking an doing anyway as it's a cheap part. The newest is revision g... the d is a piston type but leaks as it has no diaphragm. I've not had any issues with the g since the map and I'm running 260bhp part number 06H 145 710 G
  3. Bullys3
    Bullys3 Member
    191
    20
    Same as above mine went at standard, just upgrade it now as a preventative measure! I've got decision D and not had a problem there is a lot more running this than the G I think
  4. Bullys3
    Bullys3 Member
    191
    20
    Surprising how many people have got an audi s3 coming from the Vxr I've done the same never buy a vauxhall again
  5. turbonutz
    turbonutz Active Member
    421
    61
    well ive had running problems recently with my S3 which is mapped to stage one which ive resolved over past few days, had a shot on rolling road and diagnostic on friday ordered a revision D valve and replaced my revision G (which is older diaphragm one) which was totally deteriorated and had car back on rolling road today, totally different result!
    this is power to wheels, guy that ran dyno with me said to add on 40 odd for engine power, so would be running there abouts 305bhp (should maybe be bit more if ma exhaust wasnt blown and a maybe a crack on airbox)
    Grey line was first run with old totally f**ked valve and black was with replacement, some diffrence!
  6. S3Alex
    10,734
    4,771
  7. S3_Jacko
    S3_Jacko Well-Known Member
    1,735
    574
    Alex I was looking at that valve as i'm hoping to get my stage 1 done soon... is it worth fitting the valve 1st and run a couple of tanks of super juice to let your ecu build up some data before getting the file sent away for tweaking?
  8. S3Alex
    10,734
    4,771
    I don't think the valve alone should make a lot of difference,other than that you know it won't be leaking,or even likely to.
    I'd have the map and DV installed and the ECU will adapt over about a week's worth of running.
  9. S3_Jacko
    1,735
    574
    cheers mate... hoping to get it done in the next couple of weeks, looking forward to it
    S3Alex likes this.
  10. Gfermer
    454
    72
    Cheers guys just going to order the gfb DV this week and get it on may Aswel for the cost of £100 don't want a silly problem after my map
