How many miles...
A3 Sport Apr 13, 2009
  1. A3 Sport
    A3 Sport Member
    216
    until my 1.6 is run in? Its at 400 miles now... how much longer until it really begins to loosen up?
  2. DiscoPanda
    DiscoPanda Member
    159
    How have you been driving it?
  3. A3 Sport
    A3 Sport Member
    216
    Not hard, not soft, kinda inbetween tbh! Like revving it to 4000RPM every now and then. The highest Ive revved it to is around 5500RPM (only twice when needed a quick getaway), so its never been red lined or anything.
    Most of the time though Im revving it to 2500 - 3000RPM.
    Thanks for your quick reply!
  4. Lee_R
    Lee_R Active Member
    2,499
    12
    You still have to run new cars in? I thought that was a thing of the past! They do all their running in when getting the nuts revved off them in the factory!
  5. DiscoPanda
    DiscoPanda Member
    159
    Two schools of thought;
    1. Thrash it from day one (I'd be terrified to do this)
    2. Use all the rev range but don't be silly with it
    I'd do number two for at least 500 miles. Sounds like you've been doing that anyway.
  6. Crunch
    Crunch Member
    118
    The 'general' rule of thumb, is that if you thrash it from new, you will get more from it but it wont last as long (not your worry - as i doubt youll keep it long enough to make any difference)
    or take it steady and it will last longer.
    Id just drive it as normal tbh.
  7. A3 Sport
    A3 Sport Member
    216
    Thanks for all of the replies, so ou reckon im doing the right thing atm? I mean, normally I average around 25mpg (urban) so cant be driving it that hard!
  8. DiscoPanda
    DiscoPanda Member
    159
    Yeah I reckon you're fine. It won't hurt to take it to the redline every now and again. Just don't bounce it off the limiter :icon_thumright:
  9. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    All engines are hot tested before they are fitted to the car, this is a test for any leaks etc before it being put into the car. The hot test isn't really a 'run in' for the engine, i would say do 1000miles or so before giving it death.
    Keep below 4000rpm for the first 500miles and then 6000rpm for the next 500miles.
    As its a non turbo engine don't worry too much about not using WOT (wide open throttle).
