How low, bit of help needed please
sk8xtrm Jan 18, 2011
  1. sk8xtrm
    sk8xtrm New Member
    14
    Hi all im new to the site, im always nosing through the posts however not posted much up to this point.
    Im needing a little help in regards to lowering my car, she has already been lowered by the previous owner however I have no idea how much i would take a guess at 40mm however I cant say for sure. Since owning her I have replaced the wheels with 18" lambo replica's now with 225/40 potenza's all around (pictures below only have these on the back and 235 on the front which are gone now :) ) but i want to get rid of the arch gap and have the wheels just on the arch. Now I have noticed alot of b5's on this forum have this stance. Could anyone tell me what I would need to lower it to? I just didnt want to go buying anything out of pot luck it and it will be the same or to low the wheels jam on the arches or something silly. Cheers in advance for the help :) Picture below shows the current stance.
  2. aragorn
    18,608
    871
    TBH your ride height in those pics is bang on. Any lower and your just going to screw up the handling.
    It looks about 40-50mm at the moment.
  3. nwmlarge
    nwmlarge flat out
    219
    you can go way lower no worries
    check my pics in the photo thread.
    if you like i can measure the arch to floor distance
  4. aragorn
    18,608
    871
    You can take the springs out and drive about on the bump stops as well if you really want to. Its still going to drive like a sack of ****.
  5. nwmlarge
    nwmlarge flat out
    219
    yeah no suspension would feel like ****.
  6. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Leave it wher it is mate, looks spot on. Mine is lower and it does my f*cking head in. Will be raising mine back up by a good 20mm or so over this weekend.
  7. eoeumc
    eoeumc Member
    118
    If its not got them then a set of coilovers would be beneficial. At least you can decide where you want it and adjust it accordingly :) And to what your roads are like around where you live/drive.
