How long, labour cost to fit 3" dp and decat
mini-si Jul 8, 2014
  1. mini-si
    mini-si Member
    188
    17
    How long would it take for a decent garage with ramp access to fit 3" downpipe and decat to my s3???? Rough guide anyone?
  2. Swervedriver
    Swervedriver Member
    91
    I'd like this info as well.
  3. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Pipeworx charged ~£200 to fit mine, together with a non-res miltek system and backbox.
  4. mini-si
    mini-si Member
    188
    17
    Cheers for the info mate. Much appreciated.
  5. foxymk1
    foxymk1 Active Member
    454
    44
    It took me 1 hr and that was with removing prop as it was a Quattro
  6. mini-si
    mini-si Member
    188
    17
    Bloody hell. Was someone timing you. Lol. That's good going.
  7. foxymk1
    454
    44
    i only had ramp time for 1 hour so they bet me i couldnt do it :) i did have a 2 poster ramp plus the exhaust had been off the week before so no seized nuts
    iv just noticed that this the 8L forum i did it on a 8P , i replied through tapatalk and couldnt tell,
  8. mini-si
    mini-si Member
    188
    17
    Still good going regardless mate. Fair play
  9. vroomtshh
    vroomtshh Active Member
    362
    49
    I'd expect to pay 2 hours labour
  10. foxymk1
    454
    44
    thanks man,
    but as vroomtshh says they will probs charge you 2 hours
  11. Fabian808
    Fabian808 Looking for parts :P
    78
    I have been quoted 2-3 hours for mine it's going in next week.
  12. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    196
    My friends dad did it in 2 hours with no past experience on s3 , he is a mechanic with a ramp. But I was still impressed by that, I think 2-3 hours is fair and going rate especially if there are seized bits to fight with!
    Sean
  13. dayofthejackal
    dayofthejackal Member
    35
    Mines not an S3 just an A3 1.8T and my local garage fitted a full cat back (3" downpipe, decat and 2.5" system) swapped the front sensor, took the old exhaust apart a cleaned it and bagged it up for me. 1 hour labour £50 +VAT
  14. daz-20vt
    daz-20vt Well-Known Member
    2,828
    580
    So much easier on the a3 though sadly for us.
    Lucky for you!!
  15. Drue1
    Drue1 Member
    189
    23
    Where is the cat on the s3's
  16. <tuffty/>
    21,008
    3,770
    S3 uses twin CATs as std and are in the tunnel just past the front subframe
  17. jasongtr
    jasongtr Active Member VCDS Map User
    441
    37
    and in case anyone cares the 1.8t quattro is the same as the S3
  18. badger5
    9,426
    1,973
    the downpipe is'nt tho is it
  19. jasongtr
    441
    37
    i know, i just meant the cats
  20. Fabian808
    78
    Is the dog bone engine mount easy to do when changing the dp and cats? Got a poly bushed one in considering fitting at the same time as my relentless bits.
  21. jasongtr
    441
    37
    yup, 2x 16mm bolts into the bottom of the gearbox and 2x 13mm bolts into the front of the subframe, should take about 2 minutes
  22. Fabian808
    78
    Sweet! Cheers mate.
