how long does your car heaters take warm up
khalil Dec 18, 2008
  1. khalil
    khalil Member
    774
    hi all when you first start the car in the mornings , and if you hit the AUTO BUTTON and you have the temp set to lets say 25c, how quick does it heat up, i am asking because when i hit the AUTO button the heaters dont seem to be blowing air hard as they used too,even when i raise the temp to 27c the heater really stays on the same speed
  2. khalil
    khalil Member
    774
    oh i forgot to add, i had the windscreen replaced yesterday , if thats got to do with anything,
    many thanks
  3. h5djr
    9,247
    1,630
    The fan speed on Auto will stay slow until the heater element starts to produce actual heat and then speed up to get the interior to the set temperature. It does not matter whether the temperature is set to 19 or 27 until there is heat available. There is no point in the fan blasting away and pumping cold air into the car. If you want to you can increase the fan speed manually but it will still only blow cold air until the heater element warms up.
    If you press, say, the screen demist button then the fans will run faster to help to demist the front screen, heat or no heat.
  4. khalil
    khalil Member
    774
    oh thanks for that mate, i thought that autoglass might of buggered up some sensors or something while replacing the wind screen
  5. Matt
    Matt Active Member
    1,404
    I'm sure it says in the manual that 22 is the best temperature to have it on
  6. Nilz
    11,304
    864
    I've got an 8L, and I normally have it on 24 and it takes about 5 minutes to start blowing hot air...which always makes me happy (I love heat!!!)
