How long does it take to replace wheel bearings on a B5 Quattro?
Tom_B Jan 26, 2012
  1. Tom_B
    Tom_B Member
    292
    20
    Grindy wheel bearing starting to get on my thrupenny bits, is it complex to do? will it take a propa mechanic one hour? two?
    thanks,
    Tom
  2. Broken Byzan
    13,235
    464
    front? Back?
    Few hours max, depending on stuck bolts and pressing the bearing in and out of the upright or hub. Pretty much the same time either front or rear
  3. Oranoco
    Oranoco Well-Known Member
    3,787
    344
    Rears are a doddle, not had to do a front one in the 70,000 miles I've had the car for
  4. Broken Byzan
    13,235
    464
    On a quattro the rear and front bearings are one piece and really need a press to fit/remove. A 2wd is dead easy with a hammer and a punch
  5. Tom_B
    Tom_B Member
    292
    20
    Thanks for the replies - its the rear bearings ona quattro
  6. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    358
    47
    Need to do one on my car, again rear on quattro. As far as I know hub assembly needs to come off so you can get it pressed out, which means disconnecting ABS sensor, upper arm bolt, CV hub bolt, etc. Pretty sure it can't be done in situ?
  7. Royh1179
    Royh1179 Member
    70
    sorry to invade this thread guys but what is the tightening procedure on a b5 1.8tsport rear bearing ( FWD / none quatro ) thank you
  8. aragorn
    17,886
    688
    I generally nip them up until you can only just move the big washer behind the nut with a screwdriver and that does it.
  9. Royh1179
    Royh1179 Member
    70
    ye thats what i got told by a friend to do and have done and seems to be ok (quiet and no nasty noises or vibrations ) just prefer peace off mind espeshily as i carry my 3yr old in car,,,, thanks :thumbsup:
