how hard is it to remove s3 turbo
JoeeS3 Dec 1, 2013
  1. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
    How hard is it and approx how long would this take? With the right tools etc
    Joe
  2. Gops
    3,198
    666
    A pain. Head off job is easiest way!
  3. JoeeS3
    464
    105
    43
    Can you get to it easier from underneath with a ramp or not?
  4. JoeeS3
    464
    105
    43
    could someone give me an approximate labour cost for removal and fitting cost of an turbo on an s3 so i dont get ripped off?
    thanks
    joe
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Most Garages will take the head off, some take the engine out..so you are looking at an hefty bill either way, if the head comes off you will need an head gasket set minimum, then there is the timing belt, probably water pump while its off, all the wet stuff, oil, coolant etc
  6. JoeeS3
    464
    105
    43
  7. vivalacoulter
    vivalacoulter Active Member VCDS Map User Gold Supporter Audi S5
    409
    61
    I thought you already had it off?
  8. aragorn
    18,490
    855
    I dont think any normal garage would touch the cylinder head to remove a turbocharger.
    The Audi manual method certainly doesnt mention removing the head, and i'd imagine autodata wont mention it either.
    Some specialists on here seem to do it, as its a bit less awkward, but these folk work on the car a lot and have picked up their own tweaks and methods of doing things. Also, i really cant see that much time saved once you've done all the extra work involved in changing the cylinder head gasket, timing belt etc etc. Ofcourse if these bits are needing done anyway then it could pay to have it all done together, but thats not always the case.
    Personally, theres NO WAY i would entertain touching the cylinder head to remove the turbocharger. Major engine surgery to remove an anciliary component is something i just wouldnt be doing. I'd rather pull the whole motor out the car complete if it really came down to it.
    Audi Specify 620minutes to remove and refit the turbo on the S3, vs about half that on a normal A3.
  9. Andrew@A.L.D
    3,879
    617
    I've taken the turbo off without taking the head off, well thats before i went Top mounted BT.
    I ended up making soon tools and it added a few hours to the job
