How hard is it to fit a new front passenger door?
T0m Dec 2, 2012
  1. T0m
    T0m Active Member
    516
    26
    anyone?
    I bet its the alignment that is the hardest part?
    Tom
  2. hades-
    9,481
    646
    easy should align stright away
  3. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    its easy enuff mate. just a few bolts. used a trolly jack to take the weight of the door,
  4. marktdisport
    marktdisport Active Member
    1,195
    15
    As above trolley jack and piece of wood the lining up will be the same as we're the paint marks will be from the old hinge
  5. T0m
    T0m Active Member
    516
    26
    Cheers guys, had a run in with a polish lorry the weekend or should I say he hit me and although the damage is not that bad I need two new trims on the door and a smallish dent/crease taking out, am thinking it may be easier and cheaper to replace the door as there is one on eBay going for not much and it's black!
  6. T0m
    T0m Active Member
    516
    26
    I'm guessing all B6 front doors are the same apart from cabs or is this not true?
  7. Turkster
    2,797
    B6 and B7 front doors are the same, Cabs are not,
  8. Mike.M
    Mike.M Well-Known Member
    2,507
    169
    B7 doors fit but the panel has a slightly different mould to it.
  9. marktdisport
    1,195
    15
    B7 doors are not the same, yes they will fit and shut but the lines won't match at all
  10. T0m
    T0m Active Member
    516
    26
    Cheers guys the doors from a 03 plate A4 B6, on a separate note are all wing mirrors interchangeable from B6 and B7? people on ebay seem to say that they are the same?
