How easy is it to retrofit auto lights&wipers?
boggysv Feb 2, 2009
  1. N8
    17,163
    718
    I've got glass for the mirrors if anyone is interested
  2. Kufatec loom has shown up! Now to start trying to get my head around the wiring. :readit:
    Does anyone have parts numbers for the CH/LH connector and repair wires i'll need? I have the auto-light switch with the CH/LH button, just need the connecting half.
  3. Ash187
    7,496
    744
  4. I have the same problem as what you described below. How did you sort the issue?
    Cheers.
  5. Ash187
    7,496
    744
    that problem with the light/rain sensor was an issue with the power from the fuse box... it was loose :ninja:
  6. Just to follow up, turned out my earth wasn't happy. Moved the earth to a different bolt and now the auto-dimming rear view mirror and rain-light sensor appear to work.
    I've just tried the auto lights and they seem to stay on all the time. Sounds like you had the same issue in the past and it was more luck and a bit of fiddling that sorted it out! :sorry:
  7. paul_e88
    paul_e88 New Member
    25
    Can you tell me which bolt did you take your earth from?
    I'm having the same issues, the DIS is displaying that the light sensor is defective, and on VCDS i have two errors, one about the sensor and another one about the canbus connection.
    My earth is a "splice and join" to an existing earth wire, should i move it to a bolt?
    The thing is that i have 12v at the pins on the rain and light sensor, i checked.
    I would try any possible solution, before having to replace the sensor..i am still hoping that it's not defective.
  8. Ash187
    7,496
    744
    i use the bolt up just above the steering column to the right above the CE module. if not you could use the OEM grounding point just behind the carpet on the right side of the car behind the bonnet release lever
  9. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
    Hi Guy's, so on an OEM install how would these wires be attached? Would they really be spliced too?
  10. NHN
    29,411
    1,739
    In what respect spliced, you mean if installed from factory, if so then its all built into the cars original looms, if doing after purchase then new loom added with pins on ends to plum into connectors.
  11. Stevec83
    Stevec83 New Member
    Just being curious here :whistle2: how much would this retro fit cost from your good self ?
  12. NHN
    29,411
    1,739
    Welcome to the site.
    I'll PM you :)
  13. Benno72
    Benno72 New Member
    Could I get a price also please.
  14. Randomage
    Randomage Member Supporter
    65
    17
    Semi-related = I bought mine with auto lights, auto dim and leaving/coming home lights (53 plate). No sign of auto wipers....is that normal? :think:
  15. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,356
    472
    Are you sure? There will be no markings to say, but if you leave the wiper stalk in the intermittent setting, it should work on auto.
  16. Ash187
    7,496
    744
    Yes the older ones didn't have rain sensors. Just a light sensor on the back if the rear view mirror
  17. -Ju-
    2,356
    472
    I'm retrofitting it to mine, can i use any rain sensor as long as it fits into the mirror? The prices on ebay vary a LOT!
  18. Ash187
    7,496
    744
    It should be fine to fit any of those sensors. You may have to upgrade your ce module though.
    Pm me for more info
  19. -Ju-
    2,356
    472
    :icon_thumright:
  20. hollow
    hollow Well-Known Member
    1,404
    162
    ash i need part no for the rls sensor and light switch so i can order from tps . tried 3 different sensors in a 2009 with led drl xenon lights but with old type ce unit . non of the sensors were recognised .
  21. Ash187
    7,496
    744
    Have you got the wiring correct? as 3 sensors that doesn't work doesn't sound right.
  22. hollow
    1,404
    162
    think its the sensors tried 2 of them in in laws golf with auto light /wipers both come up with same faults ,think there an incompatabilty issue .
    golf uses the square sensor where it seems the audi uses the round smaller type .
    cant for the life of me get the tt light switch even tps sheffield haven't got stock
  23. hollow
    1,404
    162
    forgot to ask you ash what part no do you have for the rls sensor your using and which cent electric box revision.
  24. Ash187
    7,496
    744
    I can't remember which sensor i have, they are all roughly the same
    I have the F rev CE module.
    what error message do you get?
  25. hollow
    1,404
    162
    forgot wording exactly but goes on the lines of no comms with linbus . its definately the rls sensor ,not the wiring .
    its not even recognised by the ce unit or gateway
    either on the audi or the mk5 golf
