HOW EASY ARE THESE TO FIT ?
tdi-man Apr 12, 2013
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
  2. Kaibo
    Kaibo Member
    358
    14
    That should be a piece of cake, I'm doing mine soon after my mate did his, took all of 5 minutes, made a huge difference as well.
  3. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Did he do it on 2.0TDI?
  4. Kaibo
    Kaibo Member
    358
    14
    Errrm...no : ) should of thought of that, if it helps, is easy on a V6, my bad.
  5. SootySport
    SootySport Well-Known Member Team Silver
    2,862
    763
    Poly bushes are a doddle to fit as the bush comes in 2 halves. It is harder to remove the OE bush though, a press will help.
  6. tdi-man
    1,783
    64
    ok ta will get done when m8 does oil change on ramp makes it abit easyer . is that the only 1 to change on the gearbox mount
  7. max69vk
    max69vk Active Member
    862
    57
    I did this the other day on my TDI, it should have been easy.....
    It was an absolute pig!
    The insert would not go in no matter how much grease was applied and when eventually it did, it was done by pretty much jacking the car up on the insert so the weight of the car pushed it in!
    And the results once it was fitted? Now I now this thing is meant to bed in but after 10 seconds of the engine being switched on it was clear it this wasn't the mod for me. At idle it felt like I was a brick inside a cement mixer the vibrations & banging was that bad, it was that bad we jacked the car up, spent God knows how long trying to remove the thing & refit it, only to find it made no difference what so ever. We then tried raising the idle speed to smooth things out at idle but even at 940rpm the whole car was buzzing.
    Even driving with it fitted we felt every engine vibration possible, I'm sure over time it would break in better, but for me it was totally unbearable. The only option I'm left with is to possibly beat the thing to a pulp with a mallet to soften it more then fit it, or try to modify it somehow to bring it to an acceptable level of comfort. Plenty of people swear by these things, for me though it just didn't work.
  8. Ash187
    7,505
    748
