How does a s3 with 300/330bhp+ compare to e46 m3
Goubo1 Dec 24, 2012
  1. Hammy999
    Hammy999 Member
    175
    They both feel rapid and over the same derestricted road cover ground very quickly, as has been said though once it gets to the higher speeds the S3 would have lost out. On the mountain mile I would have regularly seen 145mph in the M3 whereas the S3 is running out of road by 135-140mph. I had the SMG "2" box in mine and the gear changes were much quicker than anything I can manage in the S3 which will of had a bearing on things also.
    Westy likes this.
  2. Goubo1
    Goubo1 Well-Known Member
    949
    281
    yeah we can't compete in the gear changing times to likes of smg,dsg
  3. JMB-S3
    JMB-S3 New Member
    25
    Off the mark the S3 would have the edge but as you get close towards 100mph the M3 will make up the ground no problem, I've owned a CSL and that was brutal with it having around 20hp, 30lbsft increase and around 150kg lighter than a stock E46 M3 although I have been in a fair few E46 M3's personally in my experience you would need upwards of 350hp to embarrass an M3 due to transmission losses.
    Regards
    John
  4. Goubo1
    949
    281
    Are the transmission losses big in a s3 as is it not just fwd till they slip then power go's to the rear so not a permanent 4wd
  5. colicabcadam
    colicabcadam Guest
    mid range torque means **** all when you are using the higher end of the rev range, let's face it, ragging it you'll spend most time between 6000 and 700 rpm
    an e46 m3 weighs 1550kg an s3 8l weighs 1450kg , that the weight of one really heavy guy, so it;s actually not much at all
    my money is on the m3, if you are beating the m3 i'd say it's due to the fact the m3 is in the middle of it's rev range as you've caught it off gaurd
    remember, the s3 has to spin 2 diffs, a haldex unit, 4 drive shafts and a propshaft, the m3 only neds to spin a propshaft, 2 drive shafts and one diff
    as for a k03s beating an e46 m3 - video ? because there's plenty of videos on youtube of m3's smoking 18.t in a mild tune !!
  6. colicabcadam
    colicabcadam Guest
    IT WILL LOOSE
    you have a LOT of lag there lol - 13+ seconds from 100 - 200 kph AND you had a run up to 100 kph !!
    M3 E36 3.2 100-200 - YouTube
    e46 m3 does 100 - 200 in 11 seconds, he started accelerating on 100 kph !
  7. Paradox1
    Paradox1 Active Member
    1,833
    88
    Nothing better than the unity we have on this forum lol
    colicabcadam - I'm sure there is 18T getting beaten by m3,not denying it. I'm juat talking from personal experience.
    I never said I would wipe the floor with a m3. Just from 0-100 I've never been passed by one. Like I said before,um sure it would be different from 100+
    Goubo1 likes this.
  8. BENJAMIN
    BENJAMIN Active Member
    503
    93
    I've just bought an e46 M3. I used to own a 400bhp s3.
    A 330bhp s3 is probably very similar in straight line performance. Handling wise, the m3 is very planted as it was always designed to have 340bhp, not 210.
    Loved my s3 as it was epically fast, but the m3 is such a competent package straight from the box.
  9. Goubo1
    949
    281
    A 400bhp s3 would that be around 300bhp/ton ?
  10. BENJAMIN
    503
    93
    Approx 270bhp per tonne
  11. <tuffty/>
    21,355
    3,922
    Personally I think turbo lag on larger turbo'd small capacity cars is largely irrelevant if you drive it right... all this 5th gear from 30mph nonsense will always favour the higher capacity NA engine or smaller turbo'd small capacity engine...
    Anyone who drives a BT car properly knows which gear to start off in and a 400hp S3 is an animal off the line....
    Granted they handle a little like a blancmange but a BT car once going is not laggy at all when driven right...
  12. Goubo1
    949
    281
    I totally agree with you on that
  13. BENJAMIN
    503
    93
    I quite liked the lag on mine. You could drive it slowly off boost, or like a complete nob on boost.
  14. <tuffty/>
    21,355
    3,922
    Amen to that... when I had a K04 it felt almost too 'willing' when driving normally... the BT is a lot easier to drive personally and gives me the best of both worlds... sensible off boost and mental on it...
  15. Westy
    Westy Well-Known Member
    17,443
    1,104
    I've not even come face to face with an M3 in my S3 so I can't compare but I've been in a fair few and I don't fancy my chances much.
  16. BENJAMIN
    503
    93
  17. Lewis583
    956
    91
    Not working for me Ben
  18. Andrew@A.L.D
    3,879
    617
    love how mine drives even with the lower compression but it does help been a 2.1 I can say that i think it drives better than a 1.9 Saab 150 TDI in low revs that i drive often and that feels very flat.
    With the S3 i toddle round town happily at around 2-2.5k rpms, Nice chunk of torque at 4k as the turbo is producing boost and at about 4500-4800? its hitting full boost pull all the way to 7800, shift into the next gear and your still in the rev band ready to hit warp speed
  19. Goubo1
    949
    281
  20. <tuffty/>
    21,355
    3,922
    oooo ooo ooo.... I have one... :)
    Goubo1 likes this.
  21. superkarl
    superkarl MAN OF STEEL
    9,493
    2,436
    Wish i could contribute :(
    I saw an e46 today, god they age well
    Goubo1 likes this.
  22. ReDBull
    ReDBull Member
    217
    13
    I came across a 911 GT3 once in a mildly tuned classic Subaru. We had a bit of fun on some back roads and guess he had more to lose than I did, lol. We then came to a set of red lights in a village on the edge of town. When the lights went green we both nailed it and I got a better start than him (he was in front). There wasn't much in up to 60. Then between 60-70 onwards he just f@@ked off into the distance. When we where in town at the next round about I had a big grin on my face and he wouldn't look at me. It's all about then fun!
    I've spent time in a stage 1 S3 and E46 M3, all be it along time ago. It's like comparing apples and pears.
  23. BENJAMIN
    503
    93
    My new one. Fap fap fap.
    Goubo1 likes this.
  24. Sam_
    Sam_ Down under
    3,038
    480
    Very nice. Would only look better with clear indicators ;)
  25. ReDBull
    ReDBull Member
    217
    13
    I wonder what they're up to with that Caddy in the beck ground?
  26. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    112
    Tuffty what's that in your vent.....? Is it Liquid gauge...?
  27. Goubo1
    949
    281
    what bhp is you're s3 making ?
  28. <tuffty/>
    21,355
    3,922
    Yes...
    Just over 400hp although this video was done on an early map...
    Goubo1 likes this.
  29. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    I agree with what the bigger turbos drivers say, very easy to drive off boost and as mentioned lag isn't really an issue. If you want to put your foot down you may get lag in 1 gear if you are lazy, then you get lots of power in every gear.
    When I get back in the new year I will be able to answer this thread properly by overtaking Ben in his bimmer..
  30. BENJAMIN
    503
    93
    But your car will still be a 5 door, denim blue, a3. I'll still be in an M3. Lol
    Westy and StaceyS3 like this.
  31. burns3
    burns3 Member
    224
    17
    When Welly first took me out in Bumble before buying her she reminded me more of my old hondas I had in my younger years than my other s3. Having a BT is like having the best of both worlds in my opinion so like vtec but with a hell of a lot more kick.
  32. Reesy
    3,640
    148
    this is also true.
  33. Goubo1
    949
    281
    Driving home from Kilmarnock tonight and came across a z3m coupe and i believe they have the same engine as the e46 m3.the z3m coupe is from the same town as me never knew till I seen the driver,we came up to a roundabout around it and took the slip on to the private road.i was at 70 mph in 4 th he was behind and I heard him down shift then he just planted so I did the same by the time I got going it was level at the start but the big effortless push of torque and holding 4th till the red line I had a cars length on him by then so straight into fifth foot to the floor and I was just pulling away all the time even up to speed when he would have hit his limiter so I was pretty happy with that :)
    does anyone know how a z3m coupe compairs to the e46 m3 ??
    I can't wait to get a m3 to go for it :)
  34. RobinJI
    RobinJI Active Member
    178
    e37 Z-coupe: 1450kg, 317bhp = 218.6bhp/ton, 0-100kph = 5.4 seconds, standing km = 24.4 seconds
    e46 M3 (2000): 1570kg, 338bhp = 215.3bhp/ton, 0-100kph = 5.2 seconds, standing km = 23.7 seconds
    Z-coupe's better power/weight, but the M3's slipperier. (drag coefficients of 0.37 and 0.33 respectively)
    S3 (2002): 1423kg, 221bhp = 155.3bhp/ton, 0-100kph = 6.6 seconds, standing km = ?
    Aero wise the A3's actually very evenly matched to the M3, no real aerodynamic reason the M3 would get away more at high speed, I guess the frictional losses though the 4wd might start causing some noticeable drag at high road speeds though?
    S3: 0.335 Drag Coefficient, 2.06m^3 Frontal Area, CdA = 0.69
    M3: 0.330 Drag Coefficient, 2.09m^3 Frontal Area, CdA = 0.69
    (Figures all taken from Carfolio.com, not sure on accuracy but it's always been good for me in the past)
  35. Goubo1
    949
    281
    In this it says the z coupe has 370bhp that ain't right
  36. RobinJI
    178
    Yeah, that was just a typo on my part, meant to write 317bhp, not 370bhp.
  37. Goubo1
    949
    281
    haha sound I was thinking surely not got that power as he would have wasted me lol.dont look like their is much of a difference between then z3m coupe and e46 m3
