How do you remove trim from gear stick?
ru4shaw Oct 24, 2009
  1. ru4shaw
    ru4shaw Member
    222
    im changing my interior trim over, ive done everything but i just cant get the trim from around the gear sick off
    any advice?
    thanks
  2. NHN
    29,295
    1,701
    Yeah, have you got an ashtray in the front of it or the storage cubby?
    If ashtray then open lid & pull the gear trim up from the front & each corner gently & then should come of.
    Also helps to pull the gaitor out as its only clipped into place, bend the gaitor plastic slightly to get it unclipped then the gaitor just lifts up, then just pull it up over the gearknob & leave it like that, then you can pull the trim upwards at each corner as its got a fixing in each corner thats pressure based, be careful only pull a inch or 2 or you'll break the legs of, patients required as its a £50 part.
  3. ru4shaw
    ru4shaw Member
    222
    i can see the clips on each corner but when i bend them back it still does not want to lift
    ill give it a go
    thanks
  4. ru4shaw
    ru4shaw Member
    222
    gave it a go but when i bend the 4 clips back im getting no movement at all
  5. Synchromesh
    Synchromesh :-)
    98
  6. NHN
    29,295
    1,701
    have you got an ashtray or storage hole?
  7. ru4shaw
    ru4shaw Member
    222
    ashtray
  8. ru4shaw
    ru4shaw Member
    222
    managed to do it, just needed a bit of force
    thanks
  9. NHN
    29,295
    1,701
    lol, I was gonna ask if you sorted it, but was my info of use as used those methods many times.
  10. ru4shaw
    ru4shaw Member
    222
    lol i left the gaitor on, i got 2 small screw drivers uncliped 1 side and pulled it with a bit of force and then the other side
    thanks
