How do you remove the rear vanity light plastic cover in the back of the A3
drfeelgood Oct 7, 2010
  1. drfeelgood
    drfeelgood Member
    225
    Going to replace my rear arial, before i start trying to pry off the plastic light cover in the back, is there a certain angle i can attack it from without cutting chunks out of it
  2. 1animal1
    9,978
    not realy, its a pain to take off and a pain to put back on :)
    although if your handy you can get to it through where the rear roof light is, downer is you'll still have to drop the rear plastic to undo the plugs
  3. drfeelgood
    drfeelgood Member
    225
    Does it unclip? have i gotta get a screw driver under it to unclip it?
  4. Carpy25
    Carpy25 Member
    279
    just pops out
    Rob
  5. drfeelgood
    drfeelgood Member
    225
    can you be a bit more grahic rob. What tools did you use to remove yours and from what angle?
  6. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,610
    1,525
    You can get a flat screwdriver under the edge of the plastic and gently lever the thing out of the headlining. It is held in place by four springy lugs at the front and back.
    It does not require much effort to pull out, just give it a go and you'll see.
    The biggest problem is getting to the actual aerial connectors as it is quite tight between the headlining and the roof, but pace yourself and you'll get there.
  7. drfeelgood
    drfeelgood Member
    225
    I have small hands so shouldent be too bad, hey ohhh!, nothing can be as bad or hard as trying to remove the stock stereo unit lol
  8. AaronMarsh
    AaronMarsh Member
    31
    yeah mine just pops off using a flat head screwdriver bud! although i find it easier to pry it off from the back of the light unit rather than the front for some reason :S aerial is a pain to get too but think its cos i have hands like HULK! lol!.....
  9. drfeelgood
    drfeelgood Member
    225
    Done and dusted. Wasent that hard.getting the facia off was so simple. However the new aerial has such little slack to the cable, was a bit of a job getting it to meet up. However all done, a nice new aerial, the old one was rotten! However trying to find a small spanner which can fit 22mm bolts is impossible, so used the 17mm bolt from the old. Thanks guys.
