how do you remove the interior panel from avant tailgate ,help
lee red Mar 17, 2011
  1. lee red
    lee red Member
    ok guys can yous point me in the the right direction please ,i need to get at my rear wiper and tail lock,i had a go this morn but can only get so far with it ,i have taken the 4 torx screws out of the front side of the panel and unclipped wat i can see 4 of inside the panel, this is were im at it is still not free all i can see is a screw inside on each corner the far corner, do these need to come out, if so how do get to them coz they are well out of reach unless you have very slim arms or a very long screwdriver about 3ft ,...so hows it done without damaging owt , any help much appreciated. 2004 18t sport avant.
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    there are screws behind the warning triangle and some in the front face then its pull like hell because there are spring clips on the rear of the panel which fit into slots in the steel of the tailgate. you can lever these out 1 by 1 with a long screwdriver or prybar starting from one side and working your way across.
  3. scott b
    scott b Active Member VCDS Map User
    1,254
    as above, if you get stuck, dont mind getting off for you (only in warrington)
  4. quattrojames
    14,050
    578
    It's that classic case of "How hard do I pull without breaking the tabs off?"!
    This might give you an idea of where the
  5. sc00byd00byd00
    sc00byd00byd00 Frank and Beans............... VCDS Map User
    230
    LOL !
    I struggled with mine, even with said diagram, but in the end, I just ended up relying on pure BRUTE FORCE !! LOL
  6. lee red
    lee red Member
    exellent thankyou all ,james big thanks for the diagrams ,scott thanks for the offer matey if iam struggling i mite give you a shout ,think were i was going wrong was that i was only seeing/popping 4 of spring clips not the 6 ..doh
  7. sc00byd00byd00
    230
    Hard bit is the 2 hooks eitherside of the bottom of the rear screen, hard to explain over words. Easier by phone. When u next having a go ? You could give me a call if you want ?
  8. lee red
    lee red Member
    cheers scooby i mite have a look this afternoon about 4/5 ish i will pm you my number ,give me a txt then i will have your number to call if i get stuck.
