How do you know which is which lol?
bluequattro Sep 26, 2009
  1. bluequattro
    bluequattro Member
    411
    Hey guys, im halfway through my retrofit bt mod, but am now stuck? as most of you know there is a wiring guide on top of the rnse, how can you tell which connector is which? as two of them have exact same numbers wrote on them ie connector c and connector b:readit:
    Cal
  2. aristides
    aristides Member
    550
    Check the top of your RNS-e there should be a diagram about the pins.
    Well if you can`t here it is :)
    Just be sure to look at it from the right angle!
    EDIT: Ok my bad i didnt see that you already have the wiring diagram
    Just locate the FUSE mate and then you can understand which connector is which.
    At the way you are holding the quadlock you should mirror my image and you`re good to go :)
  3. aristides
    aristides Member
    550
    Maybe this could help
    I did that when i was trying to locate the wires :)
    Remember, the FUSE is your help!
