How do you ground pin 1?
vwgtiking Jul 13, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,030
    I got clocks out and see where to gnd it but how do i wire from pin 1???????
  2. vwgtiking
    1,030
    I need something to put in there the plug to make a connection.
  3. vwgtiking
    1,030
    In the end I bought a wire from Audi. Part number. 000 979 009 E
  4. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Scotch lock would suffice, two wires crimped on same connecting pin?
  5. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    all I did was pull the plug apart its easy enough insert a bared bit of wire into pin 1 slide the cover over to keep the wire in place and bare the other end and put it on a bolt to ground it job done
  6. hades-
    9,481
    646
    on every B6 i have done theres never been a wire in pin 1
    B7 has it
  7. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    if you dont mind me asking but what is this actually for ?
  8. hades-
    9,481
    646
    to stop the washer warning comeing on the dash
  9. s8craig
    1,753
    56
    You can't scotch lock into a wire that does exist. this is a DIS retrofit and required a new ground wire to pin 1 of the 32 pin connector (grey one I'm guessing)
