how do you clear faults?
shufti Sep 2, 2007
  1. shufti
    shufti Member
    211
    i got an airbag fault afgter swapping over a steering wheel?
    how do i clear the code? I'm not very clued up with vag-com!
    any help appreciated
  2. wallacr
    wallacr Member
    260
    It should be as stright forward as viewing the fault within that module (eg. Air-bags) and then selecting the clear faults button.
    That said, if you've swapped the steering wheels and perhaps the air-bag too, you may have to change some coding. Not 100% sure on that though, as I haven't swapped a steering wheel myself, although I do plan on a multi-function one at some point.
    Hope you get it sorted.
    Cheers,
    Rich
  3. Rev-head
    Rev-head Active Member
    2,987
    same as above go on to control module for airbags and click on fault codes on that window on the bootom right hand side there is a clear fault code button
    If there are none you need to recode top line of coding think on rosstech site has code think its 12342 then apply .......copy all codes that are shown before just incase something stops working ...lol
