How do you change the passenger side indicator bulb?
jonnycraig May 23, 2011
  1. jonnycraig
    jonnycraig Member
    157
    Mornin guys,
    Prob just me having big hands lol but how do I change the passengerside indicator bulb, I cant get in enough to twist the holder out. I dont fancy taking anything apart just for a bulb or to pay some spotty teen in Halfrauds £5 to do it haha!!
    J
  2. tdia4
    tdia4 TDIPOWARRR
    613
    If your pre-facelift just pop the indicator out, all you have to do is push a little lever type thing down and the indicator unit will slide out.
  3. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
    If post-facelift (one piece lamps) its easy to take the lamp out. 3x TX40 bolts....
  4. jonnycraig
    jonnycraig Member
    157
    Cheers guys my car is a pre-face lift from 96 with one piece headlights separate indicator did look for a tab to try and get indicator out (if someone could post a pic would be awesome) so may just resort to taking it apart got a 350mile trip on friday and dont fancy doin it with the bulb out and the extra speedy indicator flash!!
    J
  5. tdia4
    tdia4 TDIPOWARRR
    613
    Audi area: Audi TT DIY B5 A4 (Pre-99.5): BPV / DV Install
    That's the best pic I can find, the top one.
    If you look at the side of the actual headlight you can see where the indicator slides in to join onto the headlight, thats where the tab is that you need to push down to release it from the headlight.
  6. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    Here you go... took this when I first had the same problem! You can see a little phillips plastic screw head. You need to turn that 90 degrees, then push down. The whole indicator will slide directly forwards. When you're all done and slot the indicator back into place, remember to turn the little screw thing again or it can fall off.
  7. jonnycraig
    jonnycraig Member
    157
    Fantastic help guys, ill get it out one way or another!!
    J
  8. aragorn
    18,299
    804
  9. Keyser Soze
    Keyser Soze Member
    78
    Change the man!!!!!
  10. jonnycraig
    jonnycraig Member
    157
    Cheers guys again, right, pry bar applied and bent the wing outta the way :jump: easy access lol!!
    Ill have to have another proper look as I cant seem to find either a tab or the twisty 90degree thingy down the whole...more investigations required!
    J
