how do you change the interior door lock pins?
jazzyc Jun 28, 2007
  1. jazzyc
    jazzyc Member
    153
    as it says above, do they just pull off or unscrew or do i need to take the door panel off?
  2. jazzyc
    jazzyc Member
    153
    just in case i did not make it clear its the black bits that stick up when you unlock the car
  3. mjc23
    mjc23 Member
    37
    They screw off, but you'll need to grip it quite hard. And then they just slide off at the end. Not too tricky really. Hope that helps.
  4. Danielson
    Danielson Member
    704
    you dont need to take the door pin off to remove the panel. just remove all the screws and lift the panel over the pin.
  5. jazzyc
    jazzyc Member
    153
    so they screw off. I was not sure as the ally ones i got from vag com look like they just push on, there is no thread in them.
    was just worried about buggering anything up on the stem that they go on.
  6. jazzyc
    jazzyc Member
    153
    ually wondered if i needed to take the door panel off to get the door pins off but it would seem i dont:icon_thumright:
  7. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    as they are made of ally they might just be able to twist them on and it should self thread them inside?
