how do you bleed the breaks
S3 chj Feb 26, 2009
  1. S3 chj
    S3 chj Member
    306
    hi iv changed my abs pump today but i can't get the breaks to bleed how the hell do you do it?
  2. nick-barnes07
    nick-barnes07 Member
    554
    i think there is a bleed valve somewhere in the engine bay as well as on the brakes, not 100% sure though
  3. grathies
    grathies More Points Than Portsmouth FC
    1,343
    Should be the usual bleed nipples
    Be careful to start with the ABS pump, if it was fitted "dry" then they can be a right ****, we used to have alot of problems with them, they seem to trip out for fun!
  4. s3ollie
    s3ollie Member
    762
    there is also two bleed nipples on the master cylinder these need doing first then work from the furthest away caliper back the the closest.
    as garth says you might also need to cycle the abs pump using vagcom :beerchug:
  5. S3 chj
    S3 chj Member
    306
    thanks guys i got a mate from vw coming up tomorrow with his computer to run the pump and code it, what a pain just to change a abs pump!
  6. abdus
    abdus Top Gear VCDS Map User
    1,827
