How do you allign headlights Help!
A4 TC Jul 28, 2010
  1. A4 TC
    A4 TC 1.8T quattro sline
    211
    10
    Hi guys just had H I D s fitted and what a big difference there is , But now ive got a problem on the beam of light outwards of 12feet or so the light suddenly cuts off, how do i correct this ? where abouts do i adjust? cheers
  2. boya
    boya Member
    384
    Am fitting mine on saturday so could do with knowing this too. Thanks
  3. quattrojames
    14,068
    585
    You'll need a proper headlight aligner to do it, but here are the screws to use:
  4. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    *** TIP ***
    If you are on Halogens and just about to go to HID's, mark your Halogen pattern on a large board a set distance from your car. (Where applicable make sure height/load adjustment is set to "0" next to light switch where fitted.)
    Install the HID's.
    Check the HID pattern against the Halogen pattern - readjust accordingly.
    This is a rough check and is no substitute for a proper alignment, but should get you in the right ball park - of course this assumes your Halogens are correctly set up!
  5. A4 TC
    211
    10
    Fantastic guide will give that a go! Thank you !:thumbsup:
  6. paul20v
    paul20v Audi fanatic
    1,114
    Goto your local mot station im sure they will set the lights up right as you really dont want to be dazzling oncoming drivers as this will make you no better than a saxo/corsa driver etc :)
