How do people buy tyres nowadays?
paul_r Jul 16, 2012
  1. Richh999
    Richh999 Member
    164
    Part worns come mainly from people who get a single puncture and then get the pair changed thus leaving one partworn, If you had 2 punctures on one side but get the 4 replaced then that would be 2 spare part worn tyres..
    Or they come from people like me who change their tyres when they don't like them. I had some P zeros put on and had them for about 6000miles and really didn't like them so had all 4 taken off and uniroyals put on and haven't looked back.. Tempted to try Vreds or PS3..
    Whats the differnce between vreds that have already done 2000miles and a set thats been on your car for 2000miles. Not much really...
  2. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    Problem with part worns is that you dont really know what youre getting.The tyre could have bee kerbed and the sidewall damaged that is not visible.If its a private sale then maybe, but youre never certain.
  3. johnnythepie
    2,242
    75
    Strange that most tests are differant, I had four conti sp3's and thought they were shyte so I ebayed them.I rate the bridgestone s001s much higher than the contis.The vredstein is highly rated by forum users.You cant win!!Im running conti sp5p's at the mo, and apart from having a soft sidewall grips like s to a blanket in wet and dry.The next poster might disagree!!
  4. kkp0897
    kkp0897 Active Member
    768
    45
  5. Minstadave
    Minstadave Member
    560
    19
    He's right though - go do some reading, find any test that shows good performing budget tyre. They're for retards.
  6. Minstadave
    Minstadave Member
    560
    19
    No it's not a generalisation it is true, go look up the figures of any tyre test. Its not about hooning is about stopping distance. Look at stopping from 70 figures. Budget tyres generally take 10m or more to stop at that speed, that puts you through the car infront. You're blinded by saving a few quid, they're a liability to you and the person you hit.
    I can't see how you can run a decent car, chav it up the the hilt with a wrap and 20" alloys but not spend a few extra quid on decent tyres which will not only improve handling but will also make you safer.
  7. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    i just did some calcs in excel to work out the costs of part worns for my size 255/35 19 contisport 3's using the camskill price as the new price, saying new tyres 8mm of tread and taking into account £10 each to fit them at each change
    the result...... most of the part worn ones on ebay are bad value! (apart from the ones that have had sidewall repairs etc)
  8. murran
    murran Well-Known Member
    1,545
    39
    true when worked out that way.
    but id rather buy a good branded second hand tyre with 5mm on it for the same price as a new budget (obviously with 8mm on it).
  9. quattro81
    quattro81 All the gear.. No idea
    970
    90
    TBH I totally agree - it's not about how fast you drive, you can't compromise on tyres and blindly ignore the fact the fact that it is others you put at risk too. If you don't care about yourself, that's one thing.. but the person you hit:no: thats plain selfish.
    I have some special plastic tyres for my R/C car that make it brilliant for practising drifting at slow speeds.. or for the road, you can do the local favourite of the little boy racer fwd cars - put macdonalds plastic tray under each rear tyre, lock hand brake on, and go!.. Admittedly I've only seen it done in a carpark, but the grip level ( or lack of ) left me speechless :)
    Seriously though, if you're not on a budget dude, why skimp - at least go mid-range! Just be thankful you only got little wheels - my q7 tyres are £340 each on a mid range tyre!
  10. murran
    1,545
    39
    i dont know how people with q7s can run them tbh.... what with the 6000mile service consisting of just front brakes and front tyres!
  11. quattro81
    970
    90
    I'm starting to wonder myself:think:... There is a cunning little way around the tyres thing, but if I told you I'd have to kill ya!:ninja:
  12. Minstadave
    Minstadave Member
    560
    19
    A3s have depreciated to the point where even the knuckle draggers can afford them it would seem. I'm bored of arguing with you.
    You can put your fingers in your ears and shout about how awesome your Chinese tat tyres are all you want.
    You havent discovered some secret and everyone else is wrong, you're being cheap and dim witted. Every tyre test ever disagrees with you, they can't all be wrong.
    Its absolutely no skin off my nose what you put on your chav mobile, just don't advise other people to do the same.
  13. quattro81
    970
    90
    You're just like my mrs.. Start an argument, then when you get pulled up on it hide behind "I'm not arguing - it's all you".. That's bad enough, but this is a technical forum designed to give safe, savvy advice to those asking - and yours is neither. Opinions are like *****, every **** has one, but yours are just designed to get under people's skin and not based on trying to help others. All this "full stop, move on" **** helps no one and only serves to push people away from what is normally a fantastic resource for all things Audi :( such a shame
  14. Ste_Nova
    1,223
    47
    i dont think you got all what i said...... your better off buying the new branded with 8mm on, as the same brand part worn is bad value when you work out the cost per usable mm and £10 for changing tyre
    buy a new with 6.4mm of usable tread + £10 for fit
    or 2 part worns with 3.2mm of usable tread + £20 to fit twice
    you might be lucky to save £10 in total so unless you can avoid any shipping if they are v local or you can fit for free or you win the tyres v cheap most ebay part worns arnt worth it
  15. N8
    17,163
    718
    Chris your an animal :laugh:
  16. Ads
    Ads License to drive
    8,230
    607
    Your post edited for correctness.....
  17. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    camskill - end of thread
  18. murran
    1,545
    39
    well of course if you can afford to go buy a new michelin for 130 its going to work out better value than paying 70 for a part worn with 5mm on it.
    what i mthought you meant was would you rather buy part worn michelin for 70 or a cheap new budget for 70? id go with the part worn.
    and yes i have free use of the tyre machine at work.
  19. The Governor
    The Governor Active Member
    526
    75
    Anyone with the new BE rotors had theirs done yet, those wheels look prime for a ham-fisted tyre swapper to knacker the polished edge...
  20. garuf
    garuf Member
    130
    :iagree:
  21. Artimus
    Artimus Shortback
    2,012
    482
    When all's said & done, tyre choice is personal & subjective.
  22. monkeynut
    monkeynut Member
    45
    tyresavings.com seemd to be better than blackcircles and mytyres etc and I just called my local Kwik-fit who proce matched plus another couple of quid off. That brought the cost of 2x 225/45/17 Goodyear Eagle F1 Asymetric 2 down from £262 to £206, happy days!! Incidentally they won the Auto express tyre test 2011, beating all the leading competitors!!
    Tyre Test 2011 | Products | Auto Express
  23. Ste_Nova
    1,223
    47
    maybe.. for me 255/35 19" £195.59 from camskill
    the max i'd want to pay for a 5mm ebay tyre delivered is £99.22 if it was 5.5mm i'd pay £115.28
    its welll worth working out your prices as some of the ebay tyres are £££££
  24. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Right, I don't want to start arguing, but reading through some of your posts, I think you need to see this...
    Tyre Safety: Premium v. Budget Tyres Wet Braking Test - Continental Car Tyres - YouTube
    Just imagine those foam blocks are a child, or a relative's child... Or your child.
  25. Benjiman46
    551
    24
    And just so I'm not accused of being off topic...
    Camskill FTW!!! Delivery straight to your door and the cheapest I've managed to find Vredestein Ultrac Sessantas for :)
  26. Ste_Nova
    1,223
    47
    for me they were £10 more for 4 tyres fitted than camskill
  27. 3DTDi
    3DTDi Member
    239
    Conti Sport 5's for me all the way, regardless of cost, best all round grip, stopping distance in all conditions. Had budgets on previous cars do have never been against them, now days, I see the light. Kelvin, put a set of premiums on your car and take it round a wet track, you will see, all these negative replies you have been disagreeing with are true Fact.
    Camskill, Blackcircles, mytyres, all are good and cheap, just compare them at the time of purchase to get the best price
  28. Ste_Nova
    1,223
    47
    what are the conti5's like compared to the conti3s?
  29. murran
    1,545
    39
    i need a pair for my 100 soon as the budgets all round are annoying me. and tyre walls on the rears are cracking up.
    im looking at these.
    2 Michelin Pilot Sport 225-45-R17 | eBay
    if they stay at £40 i'll have a bid.
  30. audicruiser
    audicruiser Audi Heaven
    1,865
    I'm with you on that PaulS3... You may pay more for a Michelin but they last 20k miles!
    Oh and talking of budgets... Well Audi's don't come out of the showroom with them on so why would you ever fit such rubbish to a premium car.
  31. murran
    1,545
    39
    but @ £82 theyre not good value!
  32. The Governor
    526
    75
    I've used Event Tyres twice, first time they mashed my alloys a bit on my 3 series, second time they were as good as gold (I should have kept a closer eye on the guy the first time).
    Their prices have been pretty competitve and they come to wherever you are which is a real bonus...
  33. andyalbert
    andyalbert New Member
